Old 14th June 2005, 10:46 AM   #1
Default motor regulator circuit
I have done this from a motor regulator for a turntable of mine, it has switchable 33 and 45 rpm, to a dc motor.
I haven't strictly drawn it correct, there MAY be errors, the first transistor is actually a fet, and I hope I have them connected the right way, but if anyone cleverer than me sees any errors, please correct them.
Old 14th June 2005, 11:30 AM   #2
ok another one here, this one is drawn slightly better, but again I have drawn with just npn bipolars, there could be errors, if anyone sees how this works, please inform.
left comes in from the bridge, 2 wires top right go to the motor.
Old 14th June 2005, 04:55 PM   #3
Default The official motor regulator circuit
now redone correctly, this is 99% right this time.
This is the reg of my turntable, with adjustable 33 and 45 rpm.
enjoy, comments welcome,. I didn't design this.
Old 14th June 2005, 06:01 PM   #4
BTw, its the reg. from a slightly earlier oigrin live psu, the advanced version.
A later ultra version has slightly more transistors, some paralled.
Motor for dc 100 is maxon 110189, a max range, 7 watt with 1.2ma start up current. 36 volts nominal 26 mm in diameter
at a guess dc200 is re max range, 226779, 9 watt.
The first terminal of the jfet attached to the input of the psu is actually the source.
Comments are invited.
Old 14th June 2005, 06:23 PM   #5
Default ogirin live info see below
thanks
Old 14th June 2005, 08:21 PM   #6
Bill Fitzpatrick's Avatar
You're welcome
Old 1st October 2005, 10:22 AM   #7
john2 is offline john2  United Kingdom
Unhappy Origin Live power supply
Re the Origin Live power supply drawings they give no resister values, the details on what particular diodes, thyristors etc., etc., are absent-it is my intention to build an Origin Live power supply, without the missing details it will be dificuilt, to say the least.
Should anybody have any details regarding the missing information and/or the latest incarnation of the Origin Live power supply I would be most grateful.
Old 2nd October 2005, 04:46 AM   #8
hagtech's Avatar
Are you sure you drew this correctly? The C3 concerns me - could be stability issue within loop. And does motor current return to select, or to ground?
Why not just use a regulator chip? Like an LM2941 or LT1129? These are pretty low noise and have adjustable versions. They combine the PNP and all other stuff (including reference) inside. Very easy to use.
jh
Please help about AC motor circuit arnoldc Analogue Source 4 21st June 2009 02:37 AM
Improving a turntable (motor controller circuit) ;) sek Analogue Source 26 15th September 2008 08:44 AM
Rega Motor connection circuit guglielmope Analogue Source 5 24th May 2006 10:21 AM
Once again DC-Motor circuit… planet IX Analogue Source 1 17th November 2005 12:14 PM
Page generated in 0.19546 seconds (45.52% PHP - 54.48% MySQL) with 11 queries
