Old 13th June 2005, 10:38 AM   #1
Default wood is good
Here is the last incarnation of my homebrewed platter, which includes wooden upper layer. I glued two bubinga boards with the West epoxy and shaped it on CNC. Than the 36 mm chunk of wood was screwed to the underlaying 10 mm brass plate with 24 bronze wood screws and bolted to the lead loaded subplatter. Thus I'm trying to address the issue of wood dimensions/shape stabily.
The most pleasant improvement I noticed was the complete absence of accoustical feedback (resonance) of the stylus induced vibrations, which are oterways bounced back to stylus and cause nasty low fq peaks. If you heard heavy trucks suddenly entering some of your records background, you know what I mean. I never managed to get rid of it completely with aluminum and acrylic platter. Now I may confirm, wood is the way to go. The hardwood vibration properties suit vinyl very well, allowing low fq to pass and being absorbed further, without overdapming and sucking life from music.
Old 13th June 2005, 10:59 AM   #2
Miniwatt's Avatar
Old 13th June 2005, 12:29 PM   #3
Very nice job! Did you give the wood any other finish treatment to seal it?
Old 13th June 2005, 02:00 PM   #4
Just 4 layers of marine grade polyurethane varnish.
Old 19th June 2005, 09:36 AM   #5
Tee-Rex is offline Tee-Rex  Israel
Default Yafe Meod
Congrats Michael - this is beautiful.
Can you explain a little further about the usage of the brass layer?
-T
"I can resist everything, except temptation" - Oscar Wilde
Old 19th June 2005, 06:06 PM   #6
Default brass
Brass serves several goals:
- prevents wood from warping (wood is screwed to it),
- takes part in providing path for low fq vibration, having it's own good sonic signature,
- hepls to damp the upper mid vibration (ringing), by having layer of sorbotane between two brass layers (note, that the rigid coupling beween them is still there by means of 12 brass discs with all package bolted together),
- adding rotational mass.
Tee, I wish you luck with your own project. It's fun, I tell you!
Michael
Wood hardener AuroraB Everything Else 9 28th August 2007 03:55 PM
Which wood? Spasticteapot Multi-Way 28 6th August 2007 09:57 PM
Wood Cylinders sdclc126 Multi-Way 10 15th January 2005 12:28 AM
Az1 mounted on wood! barossi Tubes / Valves 9 13th June 2004 03:46 PM
Page generated in 0.15915 seconds (46.78% PHP - 53.22% MySQL) with 11 queries
