DIY Turntable is completed- pics here
Thank you! I made everything except the motor. In an earlier thread, I posted a lot of info, including design sketches, and you can see there how the bearing is made. As far as the bearing is concerned, I stayed with the original plan, but I ended up making the 2 bushings out of Nylatron, a hard Nylon impregnated with Molybdenum, a lubricant. I'm using a light oil as well.
That thread is here:http://www.diyaudio.com/forums/showthread.php?s=&threadid=50913
