| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
| Thread Tools | Search this Thread |
#82 |
I found it convenient to use variable regulation for the 3*7. You can adjust the voltage precisely and you can use different voltage supply +-10V, +-12V, +-15V just for exploration. I think variable resistors do no cost that much and results are more flexible.
- BSPX |
#83 |
Just to say boards arrived today. Thanks.
Paulo |
#84 |
diyAudio Moderator Emeritus
Mine too...Thanks!
#85 |
In only four days.
What exactly does KJ think is wrong with the Japanese post? |
#86 |
Richard Murdey
This is wa-ay off topic, but ...
Japan Post is also the country's largest saving bank, with some trillion dollars in the vault. The polical moves are all about who gets to control this piggy bank, and how the money gets reinvested into the country's economy. Nothing to do with the mail service, which is stellar, or even its inefficiency. /R |
#87 |
Richard it appears to me that the conversion of the VSPS boards to take a VSPS Ultra requires:-
1) the removal of R1 and R2 2) the cutting of IN+ to IC+ track near the IC. 3) Bridge between part of track comming from IN+ to track going from C1 to IC- and 4) Bridge from IC+ solder pad to COM track. Is this correct or is there an easier way? BT |
#88 |
Richard Murdey
Sorry about the not getting back to you by email - but it was a bit more involved a question than I had time for this week. Ok, double check everything I write here: I havent done the mod myself. In its simplest form, the mod is as follows: use R1=10ohms, or bridge the pads with wire, leave out R2, and connect the input wire to the top pad where R2 would normally go. /R |
#89 |
Thanks Richard
That will work. BT
#90 |
I have a question about lm317/lm337 regulation.
Lets say for an output of 15v we set R1 = 121ohms and R2 = 1330ohms. If the maximum possible current (Iadj) flowing through R2 is 100uA (from datasheet) then the voltage across R2 (also across C2) is 0.0001 x 1330 = 0.133volts. Is this correct? I am asking because I want to use a 22uF/6.3v Blackgate Nx for C2 and I want to make sure the voltage rating will suffice. |
| Page generated in 0.10424 seconds (66.92% PHP - 33.08% MySQL) with 11 queries |
