| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
| Thread Tools | Search this Thread |
#491 |
The regular vsps sounds quite nice combined with a little more TLC in the PSU department, some decoupling caps and an opa2228.
I'm sure there is better out there, but even with a cheap table and cartridge I think it still blows my playstation out of the water as a source. |
#492 | ||||
Richard Murdey
#493 | |
Richard Murdey
..... Protos, its not at all certain that either the 627 or the 637 are a good choice for this circuit. Please give the OP27 a shot - and give everything a couple of weeks break in time - before writing it off as inferior to the Naim. Heck, for all I know the 323 might be the better sounding circuit ... but I dont think you're giving the VSPS Ultra a fair shake. Oh right, Happy New Year everyone! Unfortunately I dont think I'll have time to do kits or even board orders this year either, so hopefully having the board files available online is working out for most people. /R |
#494 |
Hi
I'm looking to build my first MM phono stage and came across the phonoclone. However, the amp I'm looking to put it in only has single supply rails - does anyone have a revised schematic for using it with single supply? Thanks in advance James |
#495 |
Richard Murdey
You can't power the circuit from a shared single supply. Ok, technically its possible, but its a horrible idea involving input blocking caps and voltage dividers. Please build the phono stage as an external box with its own power supply. -R
#496 |
thanks, thought as much, just wanted to check...
#497 |
Hi Dear,
is it recommended to use the OP27 in both stages of the Phonoclone? There are several version of the OP27, I was suggested to use the OP27G, but I see that after the G there is onother letter.... which one to buy? Thanks amd happy new year! Cukkurullo |
#498 |
Richard Murdey
The additional letter codes signify different packaging, grades, and temperature ratings. The OP27 is also made by at least two different companies. (AD and Burr Brown-TI)
You want the OP27GP. G:eneral use/ P:lastic package |
#499 |
I've built recently VSPS using modified Veteran boards with all critical components connected p2p underneathe the chip. I also omitted some output resistors. The chip is OPA627, all caps BG, resistors are Caddocks, regulators LM2990/2937. It worked pretty well by itself, but it's really good with S&B TX 103 in step up (with Shelter 901).
The setup in a picture is better than CEC TL0 with modified BiDAT.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#500 |
I love Peters stuff, but I have to yank his chain on this one....
Electrical tape holding down th tranformers, and a spring clip holding the ground down on the RCA... Too funny!! But at least he's doing it, and steadily making progress on his projects..
Troy Thinking positive doesn't make things better, it makes you a better person. |
| Page generated in 0.11510 seconds (71.47% PHP - 28.53% MySQL) with 11 queries |
