| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
| Thread Tools | Search this Thread |
#481 | ||
Richard Murdey
It is possible to add a second regulator in series, but it is not necessary I doubt it would improve the sound. Now back to Onvinyl's post. Quote:
One idea that comes to mind is to add ~100 ohms in series with the cartrige, such that 0.6 V will not generate enough current to kill anything. Its not technically a phonoclone then, but it should be a pretty decent MC stage anyway. /R |
#482 | |
I tried the mod with the series res before, and it has an additional advantage: the gain isn't easily changed with different cart's source impedances. But the sound .... suffers. No surprise here. The reason I asked is, that I can't think of a way to constantly measure for offset at the input without affecting the signal, perhaps someone else can? I will take the second best route then and monitor the supply voltages after the regs. I will have to live with the risk that a faulty chip may develop too much offset und kill my cart (those can be expensive, we know that) Of course, the risk is much lower if I don't place my circuits on a blank wire Rüdiger
"I can feel what's going on inside a piece of electronic equipment. I have a sense that I know what's going on inside the transistors." Robert Moog |
#483 |
I don't think monitoring the supply voltages is second best if that is what you are protecting against - a supply voltage drop out. Failure of op amps or signal path components is another matter, but less likely to occur? I don't know, that depends on a lot, including assembly techniques.
This is how I plan to implement protection: The signal disconnect at the cartridge has to be fast enough to limit any current surge. A small resistor and a switching transistor across the cartridge output would probably do it. Turned off, the shunt transistor should not affect the signal, but this must be verified as to leakage and capacitance. The power supplies would be filtered with a small R/large C filter. The sensing would be before the resistor and the sensing circuit would react well before the filter capacitor decays to a dangerous level. This would all have to be calculated a out, but at first glance it seems doable. I went out of the room and came back to add to this. I would use a fast reed relay as a shunt instead. Although slower, it would shunt lower offset than a solid state device and would be less likely to degrade the signal. It could even be used to interrupt the signal in series. The time to close (or open) would have to be quicker than the time for the supply caps to decay to a dangerous level. The circuit should also shut down the supply. |
#484 |
Today I've ordered the Phonoclone boards and started on the part list. I'd like to check some items just to be sure. My cartridge is a Denon Dl-103, 0.38mV output.
1. What's the best R2 value for this cartridge? 1k5? 2. Should I load both C4 and C5? (I'm planning to use Cerafine 470uF/25V) 3. What's the opinion on C8-C11? Will 2 100uF caps per channel be enough (I'm planning to use Panasonic FC)? 4. What resistors are worth spending a Allan Brandy for? I'm planning R2, R3, R4, R5, R6. The others will be normal 1% metal films. Thank you very much, Ralph |
#485 | |
Richard Murdey
The one action I do worry about is hot-swapping the Phonoclone into a power supply that is already powered up. I do it all the time and can report no problems, but if you just get it wrong and one contact is made substatially after the other two, you could perhaps be unlucky enough to strike out your cart... if it worries you, then always connect the phonoclone to the cold power supply before connecting the mains. To quickly answer Ralph's post: 1. It depends on your system. 2. C5 and C4 both have up to two capacitors each. Again its up to you to try both configurations. 3. Two or perhaps four per channel. 4. R1 - R4. |
#486 |
Quick question..
What is the value of R8, 9, 10, 11 on the VSPS? I just completed all the other parts with exception of the 337 and 317 regs and associated biasing resistors. I don't see the R8-11 resistors value on the webpage and I did a search on this thread with no luck. I can use any transformer suggested but have 12, 15 and 21 volt handy.
Troy Thinking positive doesn't make things better, it makes you a better person. |
#487 |
Hi Troy
It depends, on what voltage you want to drive the VSPS. When you look at the datasheet from the LM317 you find the (simplified) formula: Vout = 1.25 * (1 + R10/R8) Example: R8 = 120 Ohm R10 = 1,2k will result in 13.75VDC As you could think, use 1% resistors or better. About your trannies: the input DC-voltage of the LM317 should be (tumb rule) at least 4V higher than the output, giving the LM317 the "freedom" to regulate the voltage. Your 12V trannie should work for 12VDC, the 21V trannie will result in hot regulators. Kind regards Franz |
#488 |
Not that I can't do math, but I was looking to see what the "tried and not fried" values were..
I will go with a 12vac tranny and 12VDC rails.
#489 |
Hi dears,
I am new in this 3D. To be honest I tried to trace the whole 3D... but is really impossible to go through all this material. First of all thanks to Richard all the guy involved. I got here because I listened to the true PhonoCube and I was really impressed. After years and years of listening highend systems, and as a Countepoint SA-5000 owner, I thought nothing more was possible. An extended listening test showed me the extreme quality of the sound of the phonocube... but it is too expensive given the few components used. So I went back to Arthur Salvatori's page (one of the biggest guru in High end audio) and I discovered he has a good score on the phonocube. Searching the web, then, I arrived here. First of all I suggest to go the the Salvatori's page where there is also some techincal description of the PhonoCube. http://www.high-endaudio.com/RC-PhonoStages.html#ClB I don't have the money for a PhonoCube now, so for the moment I want build a PhonoClone for my second studio system... but if it will be close to the PhonoCube... I will sell the SA5000 and put the PhonoClone in my primary system! I have some questions and I hope somebody in the forum can help me: 1. The true PhonoCube has 24V psu, why the PhonoClone here is run at 12v? 2. Is that possible to remove the LM337 on the -V and replacing the LM317 with a single discrete regulator? Does somebody tried out some discrete regulator (eg. Jung SuperRegs)? 3. I am a bit confused about the sonic differences between the PhonoClone and VSPS ultra specifically arranged for the Denon DL103. I am a Denon DL103 user, so which board is suggested and why? What is the differences between a DL103 with a PhonoClone and a VSPS ultra? 4. I do not use digital sources, is that possible to add a volume pot at the output so that I will not use a line preamp? Thanks for your attention, Cheers, John Cukkurullo |
#490 |
I made the vsps ultra w/ dl103.However I was not satisfied with the sound.Sounded slightly shut in and boomy compared to unmodified circa 1980 Naim 323 phonoboards.
Used opa 627.Opa 637 oscillated despite the AW mod.I was disappointed because another simple phonostage I had made some time ago (for a friend)with opa 627 for mm cartridge from slone´s book sounded really good.
``The author always assumes that when power is applied , the amplifier will explode or ,at the very least, catch fire.´´ Morgan Jones, Building Valve Amplifiers. |
| Page generated in 0.09525 seconds (75.39% PHP - 24.61% MySQL) with 11 queries |
