The Phonoclone and VSPS PCB Help Desk
Old 8th February 2018, 02:11 PM   #3961
ALPUY is offline ALPUY  Uruguay
Hello how are you. Today I annoy them because I need help.
I always play with simulations in LTSPICE. I usually have simulations of phono preamps.
I need you to help me "copy and paste" a Laplace font for the inverted RIAA function.
I'm amateur and I can not do it.
Thanks friends of the forum.
Old 8th February 2018, 11:02 PM   #3962
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
You can cheat by setting up a little passive filter circuit to generate the inverse RIAA function. It's a simulation so you can make the output impedance as low as you want i.e. use super-low resistance values and ridiculously large capacitance.
I'd share but I don't actually use this myself. I take the output of the circuit using a flat voltage signal source and compare it in an Excel worksheet later with the reference RIAA curve. I've attached an example.
If anyone does know how to generate the inverse RIAA function directly in LTSpice using the transfer function, please feel free to jump in here - I'd also like to know how to do it.
RJM Audio website|blog
Old 9th February 2018, 01:26 AM   #3963
Thanks Richard. I am already using a passive circuit (Elliott's).
But I saw in the forum that just like Laplace RIAA can be simulated (Calvin gave me the formula to copy and paste) you can also simulate reverse RIAA.
Greetings, Josč.
Old 14th February 2018, 05:43 PM   #3964
The formula of reverse RIAA with trial and error arose.
Where in RIAA was multiplied I put it divided and etc. (The formula of Laplace RIAA was given to me by Calvin)
I think it was fine, but I submit it to corrections.
Do not forget that I am a doctor, not an engineer.
Old 14th February 2018, 10:24 PM   #3965
Richard Murdey
rjm's Avatar
Could you upload the .asc file? It would save some time if you want me to check it against my reference.
It seems right, though you have the 4th time constant in there too unless I am mistaken.
Old 14th February 2018, 11:47 PM   #3966
laplace((75µ*s+1)*(3183µ*s+1))/((318µ*s+1)*(3.18µ*s+1))/{10}
Richarg. I just play with LTSpice. What I thought was to base myself on the RIAA generator that Calvin gave me and modify in reverse. What multiplied it made it divide.
Therefore, the .asc file can not be found.
I show you the formula that emerged after the modifications.
Old 15th February 2018, 01:12 AM   #3967
Richard Murdey
rjm's Avatar
Here's a simplified version.
Removing the Allen Wright 4th time constant, the laplace transform becomes,
laplace((75µ*s+1)*(3183µ*s+1))/((318µ*s+1))/{10}
Insert the transform between the voltage generator and the VSPS input and the circuit output is the gain multiplied by inverse RIAA response.
It's convenient for working out which circuit values give the most linear response. Note that is it not a simulation of the actual cartridge, as the output impedance of the coils is not modeled.
Old 15th February 2018, 01:50 AM   #3968
Thanks Richard. I have made the modification.
Now to continue playing with LTSpice.
Old 15th March 2018, 01:20 AM   #3969
Richard. I'm joining the VSPS 400.
I could not find how to dispose in the PCB the components of the S-REG with their corresponding values.
Can you show me the PCB and the resistor values in their corresponding place?
Greetings, Josč.
Old 15th March 2018, 04:19 AM   #3970
Richard Murdey
rjm's Avatar
here you go
The Phonoclone and VSPS PCB Help DeskHide this!Advertise here!
