| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
| Thread Tools | Search this Thread |
#281 |
EDIT EDIT EDIT:::::
OK busy testing, and ...still no better ![]() What does too little gain sound like?, the breakup is quite apparent at the fading bits at the end of songs (but not limited to this). Metallised polyester vacuum evaporated aluminium electrodes Self-extinguishing encapsulation material to UL 94V-0 Suitable for bypassing, signal coupling and general purpose applications requiring high reliability Capacitance tolerance: ±5% While we are on caps, may I ask why we don't use any decoupling caps close to the pins here? |
#282 | |
diyAudio Moderator Emeritus
Are the voltages both + and - 15VDC?
What opamp did you use? Do you have another that you could insert into the socket? Do you have another phono stage to compare? Quote:
#283 |
I used NE5532... sadly no, it was the first thing I built other than the REV C, using an opamp, since very long ago...
I will get the OPA2134 and required caps (sigh) to do the other version... I'm pretty sure the chip is good. yeah got one on the sansui integrated amp... will give it a listen a bit later... must connect speaker cables etc... |
#284 | |
I used the OPA2134 in the low impedance version..still sounded great. |
#285 |
OK, switched over to the OPA chip and suggested resistors...
It sounds better but still very grainy... I used R2 2k2 R3 6k8 R4 330k R5 2M2 Could someone please give me resistor combinations to increase and decrease gain by one so that I can learn what its doing wrong... !!!!!!!!! Circuit no longer hums, one good thing from the OPA it seems, and the distortionseems more evenly dispersed rather than just in the bass and treble... Could it be that the REV C is too sensitive for the output of this phonopre...? Would changeing the gain help then? |
#286 |
Richard Murdey
Nordic,
Your problem is most likely related to the power supply, not the RIAA loop. The LoZ (or HiZ) versions and 40dB of gain, as you have built, will work fine, and should be stable, with your op-amp and cartridge. Try wiring the bypass caps directly form the opamp power pin to the signal output. Check that the DC voltage going into your LM7815 and 7915s is above 18-19 V. Check that you aren't using a non-polar cap for output coupling. Unfortunatey your posts havent improved any. No details on layout or power supply, no measurements of and AC or DC voltages in the power supply. It took about three posts for me to even figure out you were using a Grado cartridge. In short, still doing your upmost to make it extremely hard for anyone to help you. Richard |
#287 | |
Sadly I have no digital camera....
I have copied the layout as provided on http://www.geocities.com/rjm003.geo/.../diy_pho5.html PSU consists of 4 x 250uf caps as per instruction...+.1uf caps just after the regulator. I am getting 24.1V between V+ and V- inputs on IC socket. Also, I am using 7812 and 7912 (not 15) as per instructions.... Not sure about the cap you suggested... do you mean from output pin on the IC to the V+ pin? Quote:
I got that poly cap in there as per the picture a few posts back... Just confirm if you mean for this to be an electrolytic.... (I got some NP electros I can use in there...) |
#288 | |
I recommend a good MKP quality, some WIMA will do the job well. BTW: why, Richard, do you still use such a high value? The resulting roll off with a following 22k input will be 2 Hz. You could insert a 1uF cap without any remarkable loss in the bass area. Even with a following 10k stage, you will be on the fine side with 2.2uF. I always use 0.47uF in conjunction with my 50k amps. The roll off is about 7Hz. Franz |
#289 |
Ta Franz, will play around with the output cap a bit but I still think there is a simpe mismatch between the VSPS and the REV C, unless I made a stupid soldering error somewhere..
I have now added 10nf from power pins to ground as per datasheet, and added 1000ufd before the regulator... Still no joy, will now play arround with some output caps... Does R2 and R3 set the gain? |
#290 | ||
Thanks Franz ![]() Quote:
-15vd between 0 and v- |
| Page generated in 0.12188 seconds (69.87% PHP - 30.13% MySQL) with 11 queries |
