The Phonoclone and VSPS PCB Help Desk
Old 20th April 2013, 02:46 PM   #2391
Wirehead_be is offline Wirehead_be  Belgium
Wirehead_be's Avatar
Originally Posted by Bibio View Post
as far as i know shielded cable has to be terminated at one end only, but i could be wrong.
I've always been told differently, in data networks, both must be connected. Otherwise it acts as an antenna.
Old 20th April 2013, 03:06 PM   #2392
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Coax cable must have the shield connected both ends. Mic cable (twisted pairs + shield) with Rca jacks can connect the shield at one or both ends, frequently in audio only one end is connected.
RJM Audio website|blog
Old 20th April 2013, 05:40 PM   #2393
hajj is offline hajj  Lebanon
hajj's Avatar
I replaced the RCA jacks on the turntable cables with high quality ones I had lying around (the old ones were low quality, and oxidized beyond repair)
The turntable does not have a grounding cable, so while I was at it, soldered a grounding cable on a tab mounted on the turntables internal frame.
Connected everything up again, with the boards still on the workbench, and the hum was gone!
I'm waiting for the output caps to before I do any critical listening, but it already sounds better than the phono section of my yamaha receiver.
Will report back in a week or so.
Thanks everyone for the help.
Nick
Old 20th April 2013, 09:33 PM   #2394
Bibio is offline Bibio  Scotland
Bibio's Avatar
yup i used to be Cisco certed and MCSE's BSc in networking (almost) yada yada but had to give it all up.
Old 20th April 2013, 11:39 PM   #2395
Richard Murdey
rjm's Avatar
Good. So it was the RCA connectors do you think?
Old 22nd April 2013, 06:50 PM   #2396
hajj's Avatar
Most probably, since no problems are to be declared so far
Old 25th April 2013, 04:02 PM   #2397
Mr Onion is offline Mr Onion  United Kingdom
When I built my PC3 I set it for a Dynavector DV20XL (0.3mv and 5ohms)
I have now got a DVXX-2mkII (0.28mv and 6ohm)
Would changing R1 and R2 be beneficial or not?
According to the spreadsheet he gain difference is only 0.5 db
TIA
Old 25th April 2013, 11:24 PM   #2398
Richard Murdey
rjm's Avatar
No, not at all. Just keep R1 and R2 as they are.
Old 26th April 2013, 08:23 AM   #2399
Thanks Richard. Saves me burning my fingers (I mean soldering) again
Old 5th May 2013, 12:29 PM   #2400
Bibio's Avatar
if i were to feed the phonoclone outs straight to a computer soundcard (X-FI) would i need to use resistors to set a level and if so what value. would they only be placed on the L+/R+ outs?
or is the output gain not high enough to need them.
thanks
The Phonoclone and VSPS PCB Help DeskHide this!Advertise here!
