The Phonoclone and VSPS PCB Help Desk
Old 27th March 2013, 06:59 AM   #2321
Wirehead_be is offline Wirehead_be  Belgium
Wirehead_be's Avatar
I was to curious to find out. Generated a test tone with Rightmark Audio Analyser - applied an inverse RIAA-curve in Audacity - played that sample back through the Edirol and recorded the signal back again. Then analysed it using Rightmark. I believe this is what you wanted, RJM?
20Hz to 20kHz +-0.5dB
Old 27th March 2013, 09:29 AM   #2322
JBdV is offline JBdV  Netherlands
Nice!
Old 27th March 2013, 11:01 AM   #2323
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Originally Posted by vulejov View Post
OK, same simulation..
I think your problem is you don't have fine enough sampling.
Try trans 100m 90m and 1u and see what that gives you. This moves the sampling window out to 90 ms from start up (to reach steady state, just in case) and samples 10 ms at 0.0001 ms steps, for 100 000 data points and 10 complete waveforms. Overkill, probably. Increase the step size until you see artifact peaks show up. That gives you your working limit.
RJM Audio website|blog
Old 27th March 2013, 11:05 AM   #2324
Richard Murdey
rjm's Avatar
Ok, you win this round! I see you even managed to correctly reproduce the little tip up at 20 kHz from the 4th time constant...
To achieve such stellar results, did you measure/match the RIAA caps, or were they the standard kit ones?
Old 27th March 2013, 11:07 AM   #2325
vulejov is offline vulejov  Serbia
Banned
OK, but what about equation for RIAA?
What are values R1, R2, C1 and C2, how to add C2 to R2?
Old 27th March 2013, 11:33 AM   #2326
Oh, not about winning - I just love it that DIY-projects can give you great results at a fraction of expensive equipment.
The RIAA caps were not matched, I do not have a capacitance meter. They are Wima FKP2 caps (all of them). All of them 1nF, C2 made of 3 in parallel. The resistors are metal film, matched. Output cap is Wima MKP-X2 - 2,2uF. For the rest, I kept the PCB as small as possible and kept to your construction guide (star ground,...)
Old 28th March 2013, 12:03 PM   #2327
Richard Murdey
rjm's Avatar
"What are values R1, R2, C1 and C2, how to add C2 to R2?"
The Phonoclone RIAA network is expressed as 750k || 110k + 3 nF || 1 nF for
R1 || R2 +C2 || C1. Careful, I may not have been consistent in the parts labeling in the sims.
C2 and R2 add as R2 + 1/(2 pi f C2)i. i is standard notation for an imaginary number, indicating that the reactive term is 90 degrees out of phase from the resistive term.
Suggest you do some reading. "The Art of Electronics" by Horowitz and Hill is my go-to reference.
Old 28th March 2013, 06:50 PM   #2328
Banned
Perhaps you are thinking of the conventional RIAA network where the resistor and capacitor are connected as (R1||C1)+(R2||C2) and R1~10xR2. (see the input inverse-RIAA I'm using in the sims below for an example) In the VSPS/Phonoclone it is R1||C1||(R2+C2). The ratio of the resistance values are different.
I'm afraid I can not keep track..
Old 30th March 2013, 09:40 AM   #2329
Banned
There is practically just one paragraph and nothing else about the RIAA..
Old 30th March 2013, 11:18 PM   #2330
Did some further measurements in Rightmark - full results are here.
As seen earlier - frequency response is dead-on like the simulation on rjm's page (seen here):
Noise level is nice and quiet too:
Note that is not an X-Reg version like rjm ships them, this should be even better for his. I'm using an LM317/LM337 combo, using the additional ripple caps on the adjust pin (10uF). 4400uF on each rail before the regulator. 1uF tantal to decouple (like the original National specs say). Each rail has a led indicator to make sure the minimum current draw is reached.
I think this could still be improved by a CRC-style filter feeding the regs (note the small "bump" at 50Hz). Still, dynamic range is at +83.0dB A-weighted, which is already more than what vinyl as a physical media might give you
The Phonoclone and VSPS PCB Help DeskHide this!Advertise here!
