The Phonoclone and VSPS PCB Help Desk
Old 13th March 2013, 11:30 PM   #2241
Bibio is offline Bibio  Scotland
Bibio's Avatar
is the LED indicator for the power supply a 12v or just your regular 2.5v?
Old 13th March 2013, 11:37 PM   #2242
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
About the resistor values, it's part of a CRC filter designed to attenuate the high frequency noise generated by the LM7x12 voltage regulators. The larger it is the better it works as a filter, but the impedance of the power supply at low frequencies increases proportionally.
I think 10 ohms is a maximum value for the amount of resistance you want to put there, you might want to try less or none at all (jumper).
RJM Audio website|blog
Old 13th March 2013, 11:38 PM   #2243
Richard Murdey
rjm's Avatar
Just a regular led, that's why the series resistor is there.
Old 13th March 2013, 11:43 PM   #2244
Bibio's Avatar
thought so.. cheers Richard
Old 14th March 2013, 08:09 AM   #2245
Richard Murdey
rjm's Avatar
Default X-reg
Did up a quick-and-dirty sim of the X-reg voltage stabilizer in LTSpice.
I works! (duh...)
Kinda fun to play with. The spice file is attached.
Old 14th March 2013, 08:27 AM   #2246
vulejov is offline vulejov  Serbia
Banned
Looks like there is no need for X-reg.. works just like LM78/79.
Old 14th March 2013, 08:45 AM   #2247
Banned
I can not hear any difference between resistor and jumper..
Does it make sense to put a small inductivity instead of resistor?
Old 14th March 2013, 01:32 PM   #2248
Richard Murdey
rjm's Avatar
I thought about that, but I tried that idea long ago on a different RIAA preamp, and the result was quite awful. Perhaps the inductance (high Q tank circuit) interacts with the high feedback op amp IC adversely?
You are welcome to argue that LM7812 is sufficient, given surface noise of the record, parasitic noise coupling, op amp PSRR etc. etc. Indeed from a databook perspective the 3 terminal regulators don't seem bad at all**. I prefer the X-reg though, in direct listening comparison I found it far superior to LM7812 or LM317.
**The LM78xx series is quoted for 72 dB ripple rejection at 120 Hz and 50 microV noise for 10-100k bandwidth. I've just shown that the X-reg has a ripple rejection of 120 dB at 100 Hz. The noise floor is about the same, 50 microV (calculated), but the difference is that above 2 kHz the LM7812 drops below 60 dB ripple rejection. The X-reg (LTSpice simulation) still gives 120 dB ripple rejection at 10 kHz, and 107 dB at 100 kHz, where the LM7812 is down to 40 dB. Without compromising output impedance like a CRC filter would. So the difference here is easily demonstrated at least.
Old 14th March 2013, 03:44 PM   #2249
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
About the LM7812, I remember reading somewhere (I think Salas threads) that its sweet spot for noise rejection is when Vin is more than 8V over Vout. Which makes sense when thinking the Power Humpty output which is around 23V
Old 15th March 2013, 12:20 AM   #2250
Richard Murdey
rjm's Avatar
(Vin-Vout) = 7-8 V seems about right, yes. That's what most people will end up with naturally anyway.
The Phonoclone and VSPS PCB Help DeskHide this!Advertise here!
