The Phonoclone and VSPS PCB Help Desk
Old 15th January 2013, 09:12 AM   #2131
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
@pdg
Just having the unit powered up will burn in most of the components. The only exception is the output coupling caps, C3.
Don't go connecting the tuner output to the Phonoclone inputs unless you know what you are doing though. You need to add a voltage divider to simulate the correct impedance and signal magnitude.
Either break in the coupling cap before its hooked up to the board (just connect it to a transformer secondary for a few days), or forget about the whole thing and enjoy hearing the sound get better as you listen to more and more records.
RJM Audio website|blog
Old 16th January 2013, 12:08 AM   #2132
waltroman is offline waltroman  United States
From Pliton specs 160 to 225 VAC 9.9 inches wide 9.9 inches long 4.6 - 4.9 tall
Old 16th January 2013, 12:41 AM   #2133
Richard Murdey
rjm's Avatar
No they aren't.
(The 160VA Plitron will fit in the Hammond 1590F case.)
Old 16th January 2013, 04:47 AM   #2134
This is off the 160 VA info from Plitron
Weight: 5.11 lbs
Height: 4.6 inches
Width: 9.9 inches
Length: 9.9 inches
I will contact them tomorrow.
Walt
Old 16th January 2013, 05:00 AM   #2135
OK OK OK here is the deal. If you go on the E catalog, click on standard transformers, then click 12 volt you can see a group of different transformers that output 12 volts. If you click MORE INFO you get the information that I was reading. The VIEW SPECS link seems to give the correct or more expected size.
Thanks,
Walt
Old 16th January 2013, 02:09 PM   #2136
Richard Murdey
rjm's Avatar
Since the weight is approximately correct I can only assume the dimensions you have are for the box it ships in, not the transformer itself, which, I can assure you since I have a bunch of the 160VA models, is not 9.9 inches in diameter.
Old 16th January 2013, 02:36 PM   #2137
Kjeldsen is offline Kjeldsen  Denmark
I have the stereoversion, but can't see how the IC is correctly inserted. There is no marking on top, as I'm used to (similar to the marking on the print)
Old 17th January 2013, 12:23 AM   #2138
Richard Murdey
rjm's Avatar
A faint round depression on the top of the NE5532 indicates the pin 1 position.
See photo.
Old 20th January 2013, 05:11 AM   #2139
Just placed my order for a VSPS 300 kit and bought a transformer from AVEL. A 250 VAC unit for $56.00 shipped. I was thinking I went way overboard but remembered that when I sold McIntosh equipment in the 70's and early 80's that there trannies were so over built that they would run at room temp.
Has anyone added the .1 uf TDK ceramic caps to bypass the four filter caps? If not I think I will try them before trimming the leads on the Nichicon's.
Old 21st January 2013, 04:37 AM   #2140
Richard Murdey
rjm's Avatar
Hi Walt. That discussion was for a different circuit. It's unlikely to have an effect on the VSPS. If you are going to do it, put the ceramic capacitor between the opamp/socket pins 4 and 7 instead.
The Phonoclone and VSPS PCB Help DeskHide this!Advertise here!
