The Phonoclone and VSPS PCB Help Desk - Page 206 - diyAudio
Old 22nd August 2012, 12:13 PM   #2051
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Give the phonoclone 48h powered up and 10h of playback and you should have shaken the worst out of it. It will still improve over time after than though.
RJM Audio (phonoclone.com / G+)
Old 12th September 2012, 03:48 PM   #2052
If I want to use the Peter Daniels rectefier bridge,pcb, what do I do about the com?
I tried to hook it up yesterday, but no sound..
"Simplicity is the key to brilliance"
Old 14th September 2012, 07:34 AM   #2053
Richard Murdey
rjm's Avatar
The rectifier pcb for a split supply should have positive, negative and ground terminals. These connect to V++. V-- and COM, respectively.
Old 14th September 2012, 07:50 AM   #2054
dimkasta's Avatar
Peter' s instructions are clear enough
Universal Power Supply PCB
Old 14th September 2012, 10:22 AM   #2055
Dimkasta: those are different boards.
Rjm: thanks, but the hole in the vsps vises for com is to small to fit two wires...
Can i run one wire between pg+ and pg- and connect one wire to this?
Old 15th September 2012, 04:12 AM   #2056
Richard Murdey
rjm's Avatar
You can solder a standoff into the pad, and solder the two wires to the standoff (standoff: a short length of resistor lead, etc.). Or you can do what I sometimes do: solder in one lead with a little space left between the insulator and the board, wrap the lead of the second wire around the first in the open space, and solder.
Old 18th September 2012, 06:28 PM   #2057
I soldered up everything tonight and turned it on, hooked it up tp my turntable and amp, and nothing...only humming in my speakers when the rca's was going in...how do I find out whats wrong?
Old 18th September 2012, 11:39 PM   #2058
dimkasta's Avatar
Did you make all the voltage checks at the opamp sockets that Richard suggests in his instructions? Is everything ok there?
Old 19th September 2012, 01:20 AM   #2059
Richard Murdey
rjm's Avatar
First, post a photo of your VSPS build. I'd like to see both the circuit board, chassis connections, and the power supply. We'll take it from there.
Old 20th September 2012, 09:51 AM   #2060
Check your mail for pic's, please.
Copyright 1999-2017 diyAudio
