The Phonoclone and VSPS PCB Help Desk
Old 24th June 2012, 11:31 AM   #2021
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Originally Posted by rjm View Post
The output noise of the phonoclone is defined by the op amp, not the input resistors, so there is technically no advantage in using low noise resistors.
But if there is some noise on the input from those resistors, isn t that being amplified with the rest of the signal?
Old 25th June 2012, 11:52 AM   #2022
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Yes, but the additional noise from the amplification circuit itself is larger.
RJM Audio website|blog
Old 10th July 2012, 09:18 AM   #2023
bucurb is offline bucurb  Romania
Default VSPS 300i schematic
Where could I find actual VSPS 300i complete schematic, please?
Thank you!
Old 10th July 2012, 09:29 AM   #2024
dimkasta's Avatar
Here you go
RJM Audio - The Very Simple Phono Stage
Old 10th July 2012, 05:51 PM   #2025
Richard Murdey
rjm's Avatar
300i is the same schematic as the current board revision 300m so you can download the schematic including the voltage regulator from the PCB page.
Old 11th July 2012, 04:51 PM   #2026
Default Thanks!
Thanks,
I did fix all issues.
In the VSPS 300 Dual-Mono MM Phono Stage with X-reg setup it's furnished, for capacitors C3, two white coaxial AV 1.7uF (1.9uF measured). Did someone try other capacitor brands please? Any comments about C3, please?
Warm regards,
Ion
Old 11th July 2012, 06:17 PM   #2027
dimkasta's Avatar
Caps are like ice cream... depends on what you like and how much money you got to spend
If your pockets are deep enough, they can even have gold in them (both ice cream and caps )
Now before you go around changing stuff, make sure that you give your phono a chance to properly break-in. That includes both C3 and the regulator caps, inner and outer wiring and the entire construction in general. From my experience, a month of moderate daily listening is more or less enough. And changing as much as a bridge wire or resoldering a component can bring the process back for the system.
After that, you can start switching stuff, giving them in turn enough time to break-in before you make any judgement on their performance.
Now if you need a more specific answer on cap brands, you will have to balance yourself price and performance expectations. Personally I also took into account my personal no-specific-reason liking towards brands and looks (yeah I admit it... I m shallow). I tried the vishays that Richard sent me with the kit for a month or so, then switched to Mundorf Supremes (no oil, no gold, plain black ones). A friend also built a p2p phono very close to VSPS and tried Solen and Auricaps, but he is using a custom made transformer stepup that I really do not like, and he keeps switching them before (imho) they have the chance to break-in and get comfortable.
From my up till now experience, I still vote for Mundorf. I would like to test some VCaps at some point, but for now my pockets a bit shallow...
Old 12th July 2012, 03:09 AM   #2028
Richard Murdey
rjm's Avatar
C3 is worth upgrading from stock, but you probably have to spend at least $15 ea. for something that sounds significantly better. Suggest 2.2 uF Multicap or Mundorf.
Old 12th July 2012, 05:12 AM   #2029
Hello,
I appreciate your answers. Thank you for your ideas.
In my opinion $15 x 2 it's less important. Your experience is very important for me.
I would wish make the sound of my VSPS as good as, reasonable, possible.
More details about what Mundorf, in your experience, would be more appropriate for VSPS 300i, please?
Or what Multicap capacitor, please?
Have a nice day!
Warm regards,
Ion
Old 12th July 2012, 03:55 PM   #2030
Richard Murdey
rjm's Avatar
As dimkasta wrote above, its really not a case of what is appropriate or not but rather what you feel comfortable with, and comfortable paying...
The Phonoclone and VSPS PCB Help DeskHide this!Advertise here!
