| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#2011 |
Honestly, there isn't anything "wrong" but it just doesn't sound like I want it to. Its really a great sounding setup, but not quite "there". The caps may do the trick.
Evan
Yeah... it seemed like a good idea at the time. |
#2012 | |
i've got the mundorf's here and going to try them when time allows ![]() cheers Woody |
#2013 |
Thanks Woody. Please keep us updated! I definitely want a bit more top end "sparkle". It really is a great phono stage though. I can get mundorfs locally, so that's particularly interesting.
Evan
#2014 |
Richard. Having read Happiness is Z Shaped I was wondering about using z foils as R1 in my PhonoClone. Not cheap I know but worth it? What do you think?
#2015 |
Dimitris
Well it s when people start talking about miraculous changes that I try to hold a small basket... Especially the RF suppressing change described is a bit suspicious...
It could be a nice test though. Lots of people regard them very highly. If I had easy access to some I would give them a try. Perhaps I will try to get some with my next order and try them along with my next mod to increase the gain a bit |
#2016 | |
Mark |
#2017 |
Richard Murdey
I would allow 3 de/solder cycles, max, total. Any part you might want to change more often should be mounted on standoffs. You can buy little gold pins for the purpose, or simply solder a wire lead into the pads, and solder the component to the wire lead stub.
#2018 | |
Richard Murdey
A bulk foil resistor also has very low inductance, which can have certain advantages re. RFI interference or feedback stability. My opinion? I don't think the improvement will be worth the cost in this application. If I was going to try, though, I'd go with the Vishay as being half the price and properly encapsulated as well. |
#2019 |
Thanks Richard. Thats saved me a fair wad (I'd have needed 4 as I need 5ohms on the input side)
#2020 | ||
Dimitris
Another approach I have seen around is soldering the resistors directly on the RCA sockets. |
