The Phonoclone and VSPS PCB Help Desk
Old 1st April 2012, 09:23 PM   #1911
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
I just finished listening to some records after installing the Mundorf supremes and splitting the supply into two mono parts.
The only set-back was that I had to use the 120VA toroids since I do not have a second 160VA.
First thoughts is that the change was quite impressive (despite the smaller toroids). Stereo image is wider than ever, focus is amazing and micro-details are now flowing everywhere. It s almost spooky.
Unfortunately the problem with the mid-lows still persists, making the super detailed sound a bit tiresome (I should give the mundorfs a couple of weeks).
Oh and the two cases thing is a bit of a problem for grounding. I m getting some more hum than before, even with the internal wiring signifficantly shorter and cleaner.
I really should get a bigger single case and fit the two boards in there (still full dual mono, but single earth points).
I also ordered a Jelco HS-25 headshell so that I can fix my azimouth problem too.
Tomorrow I m also throwing a new mouser order for a second 160VA toroid, resistors to fix the voltage divider, Panasonic FR capacitors for the x-reg, new bigger case and neutrik RCA sockets. And I m pretty sure I am forgetting something...
Old 2nd April 2012, 01:47 AM   #1912
jcowling is offline jcowling  United States
Default Phonoclone picture
Sorry the picture did not show up before.
First impressions:
Very quiet. Loads of detail. Punchy bass. Good imaging.
Glenn Gould, Goldberg Variations (1982): great attack and decay, lots of overtones, excellent dynamics.
Donald Fagen, The Nightfly: lots of punch, vocals are rich and detailed, drums have lots of snap, bass is clear and distinct.
Stray Cats: Built for Speed: Not a great recording. Sounds a little harsh.
Ry Cooder: Jazz: Nice detail and balance. The tuba actually sounds like a tuba. You can feel the Ry's aggressive finger picking.
I have been a little disappointed with the sound of the Clearaudio Concept table with the Clearaudio MC cartridge through my Project Phonobox SE. Not anymore. The Clearaudio really shines with the Phonoclone.
John
Old 2nd April 2012, 11:49 AM   #1913
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Color me not surprised. Well, good that things improved, and you got your PC3 up and running. It looks very nice, by the way. The power cable placement is a little unfortunate, but with such a small enclosure it can't be helped.
/R
RJM Audio website|blog
Old 2nd April 2012, 03:23 PM   #1914
I am not getting any hum or artifacts that I can notice, so the proximity of the power wiring to the output wires does not seem to be a problem.
I will change to a bigger case when I assemble the B-boards.
Next up is a pair of the Manzanita OB speakers and a couple of power supplies for my Squeezebox and rDac to replace the wall worts.
Old 8th April 2012, 12:45 PM   #1915
dimkasta's Avatar
One week further into breaking in, and things finally seem to have fallen in place.
The VSPS 300 with the Mundorfs has finally shown its teeth. The Nichicon electrolytics required about 100 hours of breaking in. At the moment I do not feel the urge to change anything, as it simply surpasses any phono I have tried (including some that worth a few thousand euros).
The only changes that I will try (mostly because I have already ordered the parts) is to fiddle with the X-Reg divider to give 10V to the op-amps, a single big case with single grounding points and better wiring arrangement with pure silver wire to further reduce the minor humm that still remains (probably from my 3f tonearm cable) and finally replace the 120VA toroids with 160VAs again. Oh and I want to replace the umblicals with something... nicer than the plain power cable...
This building experience has been a real eye opener about the design and quality of some so called high-end devices...
Oh and the phono is a perfect match for the LightSpeed passive preamp.
And here is some porn because I know you like seeing stuff (leds are white not blue... damn white balance...)
The Phonoclone and VSPS PCB Help Desk-dim_0760-jpg
The Phonoclone and VSPS PCB Help Desk-dim_0759-jpg
The Phonoclone and VSPS PCB Help Desk-dim_0758-jpg
Old 9th April 2012, 07:35 AM   #1916
Richard Murdey
rjm's Avatar
Fun fact: White LEDs are blue, the camera is being more honest than your eyes. There's a phosphor in front to convert the blue light to longer wavelengths, so the total output looks white, but there is still a strong blue bias, especially around the edges where more of the original blue light leaks out around the phosphor.
Old 10th April 2012, 08:50 AM   #1917
dimkasta's Avatar
Hehe yes those damn thingies have a bluish tint anyway. But still there should be no "camera being more honest than the eyes"... A camera should be honest to what the eye sees... anyway, it s hard to balance the colors even manually when you have 3 different light sources with different tints (tungsten ceiling bulb, actinic blue from aquarium and fluorescent green from desk light)
Yesteday I moved everything into a big single case with clearer cable topology with power, input and output on completely different sides of the case and nice big Neutrik sockets for everything.
Unfortunately it was late when I finished and could not test it on proper listening volumes, but a first impression from low volumes was that it has cleaned up a bit, although bass seemed a bit leaner (could be the new cabling).
Today I will also replace the 120VA toroids with the 160VA ones, and that will be all for now...
Going to work on my turntable next.
Old 10th April 2012, 08:30 PM   #1918
dimkasta's Avatar
OK done with modifications for now. 160VA toroids are installed.
Whoever still doubts the "big toroid" advise, I have just one sentence for you.
JUST DO IT... In capitals... as in DO IT NOW...
The dual 160VAs gave so much body to the music (on all frequencies) it is unbelievable. The difference from the 120VA when I used only one toroid and still had the vishay MKPs on was not so big. With the Mundorfs and full dual mono topology, the difference is insane.
And here is a photo of my final chassis (no white balance this time, so that you can see the white leds properly ).
Might seem a bit weird, but it was well thought of. All cables are far away from each other. Input is on the top to allow the cable to "float" away from all other ones while coming straight from the tonearm (still have work on that area).
The output is on the left side, while the power input is on the right. This besides from keeping them away from each other, will also allow for easy plugging/unplugging when I move it to its permanent place. Not very WAF friendly, but meh...
The Phonoclone and VSPS PCB Help Desk-dim_0765-jpg
Old 25th April 2012, 04:19 PM   #1919
ourdogmax is offline ourdogmax  England
Red face Can anyone help, please.
Hi everybody.
I'm Darrell a newbie, nice to be here.
I do however have a small problem. I have built a pair of Phonoclone 3 boards and strangely they sound quite 2 dimensional, mono it you like.
I suspect it my bypass caps but would like to be sure before changing anything.
They are Elna Silmic II.
I know they can over smooth in the signal path, can they do thins in the bypass position, or am I barking up the wrong tree?
Thanks in advance.
Daz.
Old 25th April 2012, 05:02 PM   #1920
Sorry for the poor speeling, I'm on medication.
The Phonoclone and VSPS PCB Help DeskHide this!Advertise here!
