The Phonoclone and VSPS PCB Help Desk
Old 12th January 2009, 11:36 PM   #1031
juluska is offline juluska  Ukraine
Default thanks AHAJA
Originally posted by ahaja
Hola.
These tricks much improve the sound.
VSPS and also Phonoclone.
...and:
Following your advices i changed the rectifier bridge for two schokky diodes rectifiers with parallel capacitors and added one 47uf and 100nf caps next to the opamp +v and -v. I am impressed how well it sounds now. Now i'm going to change the riaa network with your modifications. Can you explain with plain words hows this modifications can improve the sound?
Old 12th January 2009, 11:37 PM   #1032
photos
Old 12th January 2009, 11:44 PM   #1033
photos 2
Old 12th January 2009, 11:56 PM   #1034
ahaja is offline ahaja  Poland
ahaja's Avatar
:-) I know that it works.
Thorsten wrote about it here: http://www.diyaudio.com/forums/showt...315#post388315
Curently I'm working on these projects (pcb) on our polish audio forum, and it looks: http://www.audiostereo.pl/forum_wpis...at=48037&p=1#k
Two layer pcb.
Another mod is place on the top of opamp beetwen power legs cap 220-470nF. Wima MKS4 (raster/pcm=10mm).
Regards Krzysztof
Old 13th January 2009, 06:50 PM   #1035
Two layer pcb.
Regards Krzysztof
Excuse my little knowledge in electronics. I guess the modified schedule for beginners is this:
Am I right?
Old 13th January 2009, 08:01 PM   #1036
ahaja's Avatar
Hello
Rather you're wrong.
I think you should do that way (if you made your pcb and connections based on layout from Richard's site !).
K
Old 13th January 2009, 08:02 PM   #1037
ahaja's Avatar
Because (if I checked correctly):
K
Old 13th January 2009, 08:38 PM   #1038
Hello
K
Soldering in this very moment. I think this night i could listen it.
Old 13th January 2009, 09:06 PM   #1039
Uff, this is jewelry work...
Old 13th January 2009, 10:29 PM   #1040
Hello
K
DONE
At first glance very good results, more detailed LF.
My reference lps:
Something Else, Cannonbale Adderley
Tom Waits, Asylum days
Ella Fitzgerald & Louis Armstrong compilation
Dire Straits, Love over Gold
Thank you very much Ahaja, BRAVO!!!!!!
The Phonoclone and VSPS PCB Help DeskHide this!Advertise here!
