The Phonoclone and VSPS PCB Help Desk
Old 31st December 2008, 08:50 AM   #1021
Kevlogg is offline Kevlogg  United States
Originally posted by chrismercurio
I haven't read the whole thread. Has anyone powered this with a battery?
Yes, I have seen several people do it with a battery. However, from what I have read, best results come from higher voltages and also form the toroidal transformer.. Less magnetic interference if I remember from physics.
Originally posted by juluska
Kevlogg, this toroidal is enough. 5VA is enough, but the bigger you can use will be better. I've used a 50VA. If you are going to do more projects you can use a bigger toroidal to probe another amplifier pcbs.
A very low noise is always present from the toroidal, if you can chose an en capsulated toroidal.
Think in doing it point to point in a protoboard, is more flexible and funny.
Probe with double bridge fast rectifiers and also with schottky discrete double rectifiers. I've probe this and the sound diferent.
cool, thanks for the reply. I will check out those rectifiers. I will also look into a buffer power supply. What I meant to ask is this.... is there a formula I need to know to to equate (match) the rectifier to the transformer. or will any combination work> I am not familiar with (Va- this must be some kind of power measurement?) and rectifier properties.
( I do have a basic understanding of how it manipulates the power supply from AC to a "rippled DC")
I contacted my professor, and he is willing to work out this first project with me, he remembered his first job working as an audio repair technician
at this point, I can't wait to start!
Old 7th January 2009, 08:54 AM   #1022
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
Originally posted by Kevlogg
This should work, correct?
http://cgi.ebay.com/ws/eBayISAPI.dll...tab%3DWatching
Its not too surprising to see come around for the third or fourth time. At over 1000 replies, I don't get mad at people anymore for not reading the whole thread...
Don't use a battery. Use the biggest, best transformer you can afford.
Realistically, though, a 25VA or 35VA toroid with 2x12VAC will do the trick nicely. That one on ebay, or something similar from Digikey or wherever. It should be about $20, less if surplus.
Diodes: use a bridge rectifer, or two, bigger current is better, but anything above 1A and 100V is fine.
And don't forget the fuse.
Old 7th January 2009, 03:33 PM   #1023
chrismercurio is offline chrismercurio  United States
chrismercurio's Avatar
Dumb non-EE ?,
What is the formula for voltage after bridge rectification? (please use the VSPS as the example)
Thank you,
Chris
Old 7th January 2009, 03:54 PM   #1024
troystg is offline troystg  United States
troystg's Avatar
Dumb non-EE ?,
Thank you,
Chris
secondary AC voltage x (times) 1.4 will get you the DC voltage assuming you have filter caps.
12VAC x 1.4 = 16.8VDC
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 7th January 2009, 03:54 PM   #1025
juluska is offline juluska  Ukraine
12 V X 1.41 - (2X0,70) =15,52 V
Old 7th January 2009, 03:59 PM   #1026
2 X 0,7 is the voltage drop if you have a full wave rectifier bridge, if you have only one diode it will be only 0,70, and if you have schottky diodes it will be about 2 x 0,30 or 0,30
Old 7th January 2009, 04:14 PM   #1027
troystg's Avatar
You are absolutely correct, but if a person doesn't know how to calculate AC to DC voltage I wasn't going to throw diode voltage drops, wire/trace resistance and cap ESR at him.
But you are 100% correct...
Troy
Old 7th January 2009, 09:49 PM   #1028
tube 300 is offline tube 300  Netherlands
hello how much gain in db is the Phono clone when i use this cart ?:
coil imp 22 ohm
load imp 100 ohm
load cap 150 pf
output voltage 0,5 mv
i hope you can help me with this
Old 7th January 2009, 09:58 PM   #1029
That first circuit analysis class was quite a few years ago...and never put into practice.
thanks guys.
Chris
Old 7th January 2009, 11:27 PM   #1030
Richard Murdey
rjm's Avatar
12 VAC secondaries gets you about 17 V DC, 16 V if you use a bridge rectifier on both windings.
The simplest (VAC x 1.41) formula works quite well here, because the diode drop and ripple is compensated by the load regulation of the transformer. i.e. you lose about a volt to the diodes, but gain about a volt because the transformer is only lightly loaded.
/R
The Phonoclone and VSPS PCB Help DeskHide this!Advertise here!
