| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
Dear all:
Thanks for your comments ........ I revised my schematic ... and I will try it tomorrow ... I post the report as soon as possible ... Regards: ragil.hastomo
:: The last but not least :: |
#12 |
Electrons are yellow and more is better!
Now it's looking better. Don't forget the 100nF in parallel with the big caps. Also skip the gate resistors, adds noise. Use them ONLY if you are having trouble unstability.
/Per-Anders (my first name) or P-A as my friends call me Tube Buffered Gainclone in work |Thread |
#13 | |
in your last schematic, you would overload Q2, because it must take several times nearly the full Idss of the input JFETs. BTW, the 2SK30 is not happy when paralleling in phono input stages. I tried it. One is enough - if not take a 2SK170, as Werner already said. BTW (2), the 2SK30 has low internal capacitances, and a very high output impedance. You do more harm with cascoding that input stage, than getting benefits, if at all. So, please, make your circuit simpler. A single 2SK30 in the input, without cascode, that is enough. regards, Hartmut |
#14 | |
Banned
Just add them and you won't have to worry about it. Or the noise. Jocko |
| Which Phono Pre??? | Freecrowder | Tubes / Valves | 1 | 5th February 2009 09:45 PM |
| DIY phono to replace roksan phono stage | seroxatmad | Analog Line Level | 6 | 14th December 2008 05:46 PM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| Phono transformer VS Active phono pre | ckwong99 | Analogue Source | 0 | 2nd November 2005 04:35 AM |
| Should I replace Scott 222C phono stage with Claret phono stage? | Bing Yang | Analogue Source | 0 | 22nd August 2005 06:41 AM |
