Help about SHISHIDO Pre Phono
Old 9th May 2005, 12:42 PM   #1
Maurizio is offline Maurizio  Italy
Default Help about SHISHIDO Pre Phono
I found this complete Line Stage preamp + pre phono, from Nobu Shishido.
I would like to use the Pre Phono stage, cause actually i'm using a 6J5 SRPP Line stage.
Unfortunately, i've the line scheme only.
Anyone can help me about the PSU..?
May i use the phono stage only? I've to change something to do it?
Regards to all,
Maurizio.
Old 9th May 2005, 01:22 PM   #2
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Shishido or not it's hardly a revolutionary circuit. Still, it should work well enough.
I can see no issues connecting the phono output to a line amp of your choice. Obviously the gain of this phono is not very high so the line amp will have to make up for it.
Any low ripple PS providing 300V dc should be suitable. With minor resistor adjustments any supply exceedding 250v can be adapted.
Help about SHISHIDO Pre PhonoHide this!Advertise here!
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 06:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
Nobu Shishido's 805 SET interstage TugaTweaker Tubes / Valves 14 14th May 2007 08:51 PM
Phono transformer VS Active phono pre ckwong99 Analogue Source 0 2nd November 2005 05:35 AM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 07:41 AM
Copyright ©1999-2017 diyAudio
