| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
This may sound a little drastic but it could work - it allegedly
was the quick way to run in car racing engines in a hurry. Fill the bearing with a mixture of oil and metal polish (Brasso ?). Spin it until it loosens up. Then clean it out and run a bit with only a small amount of oil for the thrust point to polish the bushes even further then refill with oil. I've don't know how long it would take so probably best to start off spinning by hand ? As they are Teflon bushes perhaps Brasso is too drastic ? What about adding jewellers rouge powder to the oil ? Instead of the Brasso ? After the Brasso ? You get the general idea, hopefully some-one can add more knowledge to this suggestion. At $400 a pop, and I don't know if you get a new spindle, needless to say do this at your own risk !!!!!!!!!!!!!!!!!!!! /sreten.
#12 |
Hello all,
I have an odd question? When the motor is spin from the spindle, by hand, do you feel the resistance(pull) of the magnets? Is this normal? tech |
#13 |
Perfectly normal, you also get a ripple feel with AC motors,
/sreten.
| Oracle Delphi MK III speed issues...help | kilohertz | Analogue Source | 31 | 21st January 2013 02:00 PM |
| New Oracle Delphi owner questions | summilux | Analogue Source | 4 | 28th April 2009 02:33 PM |
| oracle delphi maintenance kit | Daniel-A | Analogue Source | 0 | 6th March 2005 11:41 PM |
| Oracle Delphi( Best arm for this dec) | croft | Analogue Source | 32 | 29th June 2004 05:04 AM |
| Oracle Delphi MK IV speed problem | EricSisi | Analogue Source | 3 | 5th December 2003 11:38 AM |
