Old 8th April 2005, 06:31 PM   #1
dhole is offline dhole  United Kingdom
dhole's Avatar
Default static removal from lp
Hi people.
I have this record that I bought its mint looking but seems to be full of static. It has those silly sleeves with the plastic on the inside and it crackles like a bugger. Without buying a milty zerostat or other bizare equipment is there any way I can remove the static build up ?
regards
dave
Old 8th April 2005, 06:34 PM   #2
Noobee is offline Noobee  Germany
Have it washed. Static charge will be gone for a long time
Bernd
Old 8th April 2005, 06:59 PM   #3
SY's Avatar
And be prepared for the bad news that much of that "static" isn't actually static but damaged vinyl. But a good cleaning will work wonders and get you the best that the disc can give.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 8th April 2005, 08:22 PM   #4
diyAudio Moderator Emeritus
Bas Horneman's Avatar
The standard carbon brushes often have a metal body this is done so that some static can be drained.
http://www.takefiveaudio.com/audioqu...iber_brush.htm
saa7030 removal help billbo Digital Source 12 11th August 2008 08:52 AM
Removal of SAA7220 tubee Digital Source 10 2nd August 2005 08:37 AM
Vcr tv tuner removal of foxdonovan Parts 2 20th February 2005 09:49 PM
50 or 60 hz hum removal from WAV (+) VEC7OR Everything Else 2 11th March 2004 05:39 PM
Page generated in 0.07821 seconds (73.36% PHP - 26.64% MySQL) with 10 queries
