| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I´ve been working on a TT for quite a while now, and soon she´s about to see the light of the day. The only thing that remains is the base for the tonearm, it lacks the paint so it´s not far away. The motorunit to be used is bought from Teres Audio, the arm is an airbearing Loedegaard, some pics of her, almost finished.....
Bearing mounted in subchassi, placed in sand & leadshotmix. Topplate is lexan painted from "inside". The plate is made of birch, leadfilled & oiled. The "thing" that´s still missing. |
#2 |
Stunning stuff!
It's quite interesting that you've chosen the 'older' plinth design rather than the tear-drop-swivel armboard. Any particular reason? What is the armboard material? And most importantly: how on Earth did you make this gorgeous platter? |
#3 |
I choosed this design because I wanted a rectangular base rather than the teardropshape.
And I think it´s easier to get it well damped and more rigid. The armbase is made of MDF, and will look much like the Terestype. Onto it I will place the airslider. About the platter: I cut massive longdried birch into 28x28mm ribs, glued them together to 3 "sheets". Cut each of the sheets to round shape and put them in a don´t know the english word, a spinning machine & worked them down to 320mm dia. Then I glued the bottom and centersection together & made a cut near the outerlimit in the centerpiece of about 30X30mm & filled it with leadshots. Finally glued the topplate on to it and sanded like h**l. The finnish is a type of oil, don´t know the english name, mixed with 50% tepentine. I did that until the wood was "fed", and didn´t absorb anymore (about 1 litre). Finally I wetsanded the plate with only oil and 1200 paper. I have had the platter in my listeningroom for about 1 year, just to be sure that the wood is´nt moving. I could feel some joints after a while, but they were easily sanded off. Now it´s very smooth. |
#4 |
You rule...... |
#5 |
It looks great!
I am very curious to see the finished Ladegaard as well!
Keep an open mind. It helps. Peter |
#6 | |
diyAudio Moderator Emeritus
Seriously...I love posts like that...leaving it to settle for a year and sanding again...feeding it lovingly with oil until it was hungry no more...aaah.. I've gotta build something like that before I die! |
#7 | |
#8 |
Err...the BIX sounds wonderful....incredibly quiet.....but I just assembled it...
But I still would love to build a platter like that
#9 |
Really nice! More and more stunning were your description of your making process.
It's real that good things requires time (a thing not so widespread in nowadays way-of-thinking), even if a lot of time doesn't necessarily implies to get such nice results! Congrat! Stefano (struggling to end its own TT) |
#10 |
| Looking for a turntable | bgatlin | Swap Meet | 1 | 15th December 2005 08:52 PM |
| New turntable | rocknroll | Analogue Source | 5 | 9th January 2004 05:52 PM |
| Page generated in 0.13256 seconds (70.68% PHP - 29.32% MySQL) with 11 queries |
