A really dumb open reel tape question.
Old 28th March 2005, 12:56 AM   #1
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Default A really dumb open reel tape question.
Well, this is sad, but it is actually a good question.
I'm sitting here with a TEAC A-3340S and a pile of old 7" reels and one 10" reel of Ampex 456.
I've just thought of the idea that the oxide surface must face the tape head. Looking at all the old tapes I have, the surface normally run across the head is the dark oxide looking surface.
Now, on my ampex 456 reel, I've noticed that the shiny brown side of the tape has been running across the head while the dark matte surface is out.
I'm thinking now that somehow I've been using my ampex tape inside out???
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 28th March 2005, 01:07 AM   #2
Duo's Avatar
Well, I shouldn't have spoken so fast.
I've answered my question: The tape is useless to record on the matte side.
Interesting how high end tape is different from low end tape.
Old 28th March 2005, 01:24 AM   #3
Zero Cool is offline Zero Cool  United States
Zero Cool's Avatar
Thants an anti-static back coating. brown oxide side towards the heads!
Zc
Old 28th March 2005, 08:33 AM   #4
Duo's Avatar
Yes, I have looked into some research on the topic. Interesting anyway.
I was also wondering if anyone knew anything about the 3340S tape machine?
Old 28th March 2005, 06:51 PM   #5
cyclotronguy is offline cyclotronguy  United States
Teac A33xx machines were very nice consumer grade machines. What sort of information did you need?
Cyclotronguy
Old 28th March 2005, 07:32 PM   #6
Duo's Avatar
Well, I was just interested any specifications and technical information I can find.
Also, the bias and EQ controls elude me. They simply have settings 1 and 2 respectively, instead of something more specific.
I was also wondering what to do about heads; they show uneven wear, the heavier wear being on the third and fourth track end of the heads. It still sounds fairly even, but I can tell that especially on the fourth track, the fidelity is weak. I suppose basically that I would like to get a new set of heads soon so that I can experience the full standard of the unit.
The blanking head seems to be fine, but definitley the record and PB heads are running out of life.
One last question about the machine, I find that after rewind or fast forward, there's a delay before it will do playback. Was this normal? Or is my machine acting up? (The delay is regular, it always takes the same time for the relay to click back so I can hit play.) (Perhaps I have a sticking relay, I had that in a radio once.)
Thanks.
Old 28th March 2005, 08:18 PM   #7
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
The old Revox I own behaves the same. I guess the delay is there to make sure the reels are standing still before going into play mode to avoid tape damage.
An old Tandberg cassette deck is also acting in a similar way.
/Hugo
Old 28th March 2005, 10:33 PM   #8
Duo's Avatar
Hmm, yeah, I suppose that's the idea behind it.
Though, even with 10 1/2" reels, the tape seems to always stop long before the machine will allow playback. I might see if I can somehow shorten it a wee bit, it takes about three seconds before it'll switch.
Old 28th March 2005, 11:02 PM   #9
Hmmmmm, can't tell if that is too long or not; as I don't have any plastic reels or 7 inch reels.... only 10.5 inch metal. They shift from high speed reverse to play or high speed other direction with no delay only a timed braking curve. This is on an equivalent Tascam machine (semi-pro version of the Teac 3300 SX)
Cyclotronguy
Old 28th March 2005, 11:32 PM   #10
Duo's Avatar
Lol, with plastic 7" reels on the 3340S it can stop on a dime.
A really dumb open reel tape question.Hide this!Advertise here!
Fried Reel To Reel tape recorder Clement Saggers Parts 4 17th May 2014 09:56 PM
Reel-to-reel tape decks mellowPH Swap Meet 0 22nd April 2008 08:00 AM
Reel-to-reel tape decks GK Everything Else 12 28th March 2008 09:56 PM
Paper based reel to reel tape dates Zero Cool Everything Else 1 13th May 2007 12:54 AM
Reel to Reel Tape, 10.5" richardsymes Analogue Source 6 4th April 2005 02:52 PM
Copyright ©1999-2017 diyAudio
