Old 22nd March 2005, 06:29 PM   #1
dieselpower's Avatar
Default Dynaco PAT-4/5
Anybody have expirience with the solidstate dynaco preamps, there are few for sale at a local pawn shop.
thanks
Brett
Old 22nd March 2005, 06:48 PM   #2
Bill Fitzpatrick's Avatar
I would avoid them mainly because the connectors (unplated and prone to corrosion IIRC) and switches are crummy. The pot could also be pretty much shot depending on how much use it has had.
They were fairly attractive though.
Old 22nd March 2005, 07:10 PM   #3
I have a Dynaco Pat-5 in the basement which was purchased about 1975. The circuits are, by todays standards, obsolete. However, they could be fun to DIY improve. The circuits are mostly discrete components so you can do lots of tweaking. If I recall, the Pat-5 contained 2 IC opamps, the LM 301. That sure needs a modern replacement.
Ray
Old 30th March 2005, 01:12 AM   #4
anatech is offline anatech  Canada
anatech's Avatar
I built one of these in around 1975. They don't sound that good (even then!) As I recall, nothing was very ggod, I mean controls, power supply, circuits. Just basic stuff.
If it's cheap enough they are fun to play with.
-Chris
Dynaco ST-120 botrytis Solid State 20 20th January 2012 09:34 PM
preamp suitable for Dynaco st-70- OTHER than dynaco namatjira Tubes / Valves 3 22nd December 2011 01:21 AM
Dynaco ST-410 Amp Creelove Solid State 7 22nd July 2010 05:08 AM
Dynaco A10 XO wising Multi-Way 0 24th March 2009 03:16 PM
dynaco st 70 c3 dcb50 Introductions 1 30th September 2008 11:20 PM
Page generated in 0.06855 seconds (75.36% PHP - 24.64% MySQL) with 10 queries
