| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hello! I just recived as a gift from a friend of mine this old tape deck. It dates to about 1977 I think, and it's a beautiful model in minty condition (little used) that I believe shlould be worth the effort to use in my system (I never had a tape deck). Where should I start to make it like new? Changing capacitors, transistors, things like this. And what about the mechanics?
#2 |
Hello again! I tried the tape deck after cleaning it. I cleaned the heads with normal alcool, and the sound I'm getting is very boomy, distorted and with no high-frequency content (it has nothing over 1kHz)... What should I do? The other mechanics are working well, maybe I just have to replace some capacitors (?) to extend the frequency range... I've even turned off dolby NR, but with little results.
#3 |
Is this on prerecorded tapes? If so, then the heads are likely out of alignment.
If it is on tapes you just recorded, then the bias may need tweaking.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
Yes, this is happening with tapes that I've prerecorded on my JVC mini-hi-fi, and on that they play well. On the Technics they play so bad. How can I adjust the allignment? Others suggested me of tweaking the azimuth (don't know what is) and demagnetize the head. Or just replace it. What shall I do?
#5 |
Ciao Giaime,
to adjust the alignment (or azimuth) of the head, you have to adjust a small screw which is usually placed next to the head itself. This screw helps you adjust the relative skew between head and tape. To de-magnetise the head, there are some special devices around (TDK was manufacturing a de-magnetiser in the shape of a cassette, you just have to insert it into the deck and press play for a couple of seconds). Cheers, Bruno |
#6 |
Thanks Bruno! I will try... but now the deck has started to act strangely, there's a big hi-freq oscillation over the signal, and the vu-meters stay on the max all the time... What can cause a tape deck to oscillate when some hours ago it didn't?
#7 |
These old tape decks suffered from bad contacts in the record/play switch. You can check that by pressing the record switch a few times with a cassette inserted and pause switch activated. If the VU-meters go back to normal the switch it is.
/Hugo
#8 |
Ok... don't know how I did it, but now the oscillation is gone... but before I cleaned the switch, the resistance across it was 0.3 ohms, after it measured the same. Anyway, problem solved... What can I do for that big loss of highs? Btw what I hear is wonderful, more "stereo" and involving than my JVC. I think this deck has great possibilities but it doesn't have any hi-end. I'm not using the best cable possible, but I doubt it's this causing the problem...
And what are all those trimpots inside it doing? I can't find a schematic of it... I see that the outputs are transformer coupled (yes, there are 2 small transformers on the board, about 1 cm tall and 1x1cm. Is this usual in tape recorders? Do I have to change the many electrolytics I see in the signal path for film caps? Will this improve the situation? |
#9 |
Don’t start fiddling with the trimpots inside unless you have a detailed manual.
The loss of highs is most probably what Al and Bruno said. If possible, try recording a 3Khz or so signal on the JVC. Play it back on the Technics and align the playback head. While doing so, listen with a headphone for best reproduction or measure the output of the deck with a scope and align for highest amplitude. /Hugo |
#10 |
I can't find any manual for that, neither a schematic...
I would do so, but... 1) there isn't any adjust screw; I mean the head is fixed by 2 screws on a piece of plastic that moves when I push play 2) the JVC has the record side broken Anyway I've changed the head with a new one: see results here (sorry, these two threads are running in parallel on the same subject, that wasn't my fault. Sorry again) Just got new junk from my friend |
| IC for Technics | seoded | Chip Amps | 2 | 6th July 2009 02:04 PM |
| Hafler P-230 recondition | joetama | Solid State | 37 | 25th November 2008 03:19 PM |
| Technics SU-Z65 | elec972 | Solid State | 0 | 10th February 2008 09:39 PM |
| Technics SU-600 Amp | kahukong | Solid State | 0 | 12th January 2005 01:47 AM |
| technics sl-23 | ironfinger43 | Analogue Source | 0 | 29th May 2004 05:44 AM |
| Page generated in 0.10129 seconds (87.67% PHP - 12.33% MySQL) with 10 queries |
