Completing my DIY TT - Page 2 - diyAudio
Old 1st April 2005, 05:46 AM   #11
GazzaFloyd's Avatar
Default pods
Thank for your coments
as to my pods the top and bottom plates sit inside a 100mm peice of pipe with notches in the sides to keep them centered they are tied together with threaded rod
Old 1st April 2005, 05:58 AM   #12
GazzaFloyd's Avatar
Default notch close up
sorry about the bad photo
Old 1st April 2005, 06:00 AM   #13
GazzaFloyd's Avatar
Default motor
i am very please with this
Old 23rd June 2005, 10:20 AM   #14
promitheus's Avatar
very good work!
Where did you make the bearing?
Old 24th June 2005, 08:23 AM   #15
GazzaFloyd's Avatar
Default Bearing
From my original thead :
So the first thing i did was get a local engenier to make me a bearing i have ended up with a very close copy of the Teres Audio Bearing cost on this came in well under US$80 the outer portion made out of Bronze the inner out of Stainless
I may still have the drawings if you are intersted let me know will see if i can find them.
Thanks Garry
Old 25th June 2005, 03:18 AM   #16
kilowattski's Avatar
I am also very interested in your bearing drawing.
Kilowattski
Old 13th July 2005, 10:41 PM   #17
GazzaFloyd's Avatar
Default bearing
sorry guys i know longer have that drawing
Old 6th April 2006, 12:23 AM   #18
Default the pods are finished except mounting
Just updating you guys on recent progress on my table.
I have my pods completed, I took thinkwall food grade stainless steel pipe welded a bottom into the motor pod about 1/2 inch up and the machinist came up with threding on the tops, gives a nice clean look. The tonearm pod is half the pipe and the other half is part of a copier drum pressed into this then capped in a simular way. I have a secong lower tonearm pod made and i plan on finishing it when my tonearm is done.
Now all i haver to do is get and install a motor and controller.
Old 6th April 2006, 12:26 AM   #19
Default Pods
Here are some closeups of the pods
Old 6th April 2006, 12:43 AM   #20
Default Re: bearing
Here is my drawing i used. I drew it based on Gazzafloyd 's table and teres a bit.
The machine tachnician made a few modifations to it, he used bronze instead of brass. He also used my previous steel bearing mount and machined the grove out of it and pressed in the bronze. This made it cheaper less matrerial removal time and i had the other one allredy mounted.
Use at your own risk, have fun.
Copyright 1999-2017 diyAudio
