DIY Tonearm split preamp
Would there be any advantage to locating a gain stage (and possibly RIAA) in the headshell?
The advantage I'm thinking of is possibly reduced noise, since the signal in the tonearm would be very low impedance. Of course, I'd have to feed power through the tonearm as well, but not much.
Since the power supply at the end of the arm would be compromised, I was thinking of a gain stage with good CMRR -- a low noise, single supply dual opamp (1 amp per channel).
Alternatively, if the power at the far end of the arm could be made adequate, think of something like the Pearl, with the input transistors in the headshell, and the RIAA & Output stage elsewhere. Or does this circuit already provide noise so low that my arrangement would yield no benefit?
You are not the first to have this loony idea - i used to have an SPU with a step-up transformer in the headshell. This disaster was partially rectified through bypassing the little horror but the huge effective mass was there to stay. More recently i remember seeing an ADC (not the cart brand :)) in the headshell as well...
Why try solving an imaginary problem and create a dozen more in the process? Waste a good arm with a bunch of electronic components dangling at the end? Waste a good active step-up by providing inadequate power and decoupling? Introduce more friction by the power wires in the arm?
What would the benefit of this be? Increase the S/N by 1/4db?
A real audible improvement in most arms can be achieved by rewiring with high quality, single piece of wire. A good place for the step-up would be close to the base of the arm.
Hehe, most of my ideas are much loonier than this one ;)
What's an SPU? But a transformer in the headshell? That's just plain nuts!
Since this arm doesn't exist yet, there's nothing to ruin. (I'm not planning on modifying an existing arm, but building one from scratch).
I don't think mass is an issue, because firstly the components are very light, and secondly, the rest of the arm would have to compensate. I was not imagining adding any wires, so there shouldn't be any additional friction. In fact, many tonearms have 5 wires, but I think this could be done with four.
But of course you're right, and simpler is better. And if I were to build it my way, I would have nothing to compare it to.. unless I built it both ways, which would really be loony :xeye:
too heavy to make most arms miserable.
I'm not picking a fight here. I just want to expression the opinion of the other side. (And I mean the other side, not the right or only side.) The problem isn't the SPU, but the modern low-mass tonearms. And most vinyl junkies in Europe and, especially, Japan will swear by the 12-inch Ortofon RF-297 or RMG-309.
No, simpler isn't better. Better is better.
You'd do better running a fully-balanced input with appropriate wiring.
Indeed. Balanced is the only way to go if you are to use a low-output MC cart. Otherwise you should stick to MMs, which the modern tonearms are made for anyway.
I wasn't thinking low mass. And I wasn't thinking MC either.
Perhaps. But the problem I referred to has to do with modern tonearms being low to medium mass.
Are you saying that MCs tend to be high compliance, while MMs tend to be lower compliance?
No, I said the opposite. But, of course, most MC carts these days are made for the low to medium mass arms out there.
Indeed. I was amazed how much better my SPU G/T sounded in this horrible chunk of steel and lead which was easily heavier than a Rega platter. Way better than in a 3012.
Nice! If people want to know what vinyl can be they should listen to the Ortofon combo on a Garrard 301 or Thorens TD-124. I actually settled for an EMT 929 for my Garrard 301. I had an SME laying around that I originally intended to use. It's now sold.
I have seen a very (very) small active riaa-device designed to be mounted on the headshell on the net. I probably bookmarked this link, yet Windows ME my own computer siezed working some time ago.
Maybe it will show up on a smart google search.
regards, Coen
