Old 20th February 2005, 08:15 PM   #1
Stabist is offline Stabist  Slovenia
Stabist's Avatar
Default ASMC preamp
Another simple MC pre ...
Still in test phase - waiting to be tested with 'scope - and if everything OK - also with MC head ...
Also a test version - so I decided to use NE5532 and opa2604 chips ... If any promissing results - than I'll switch NE5532 with some really quality low noise chip for input stage (eg LT1028) ...
I have a Question though - that ground/earth connector on the back side - should I connect some grounds from circuitry to it - and if - directly or through some resistor?
The schematic ain't available yet in "computerized" version ... but it's very simple ... Inspired a bit with 47labs philosophy ...
Old 20th February 2005, 08:17 PM   #2
Stabist's Avatar
another
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps MartyM Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Solid State 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 10:13 PM
Page generated in 0.08322 seconds (62.06% PHP - 37.94% MySQL) with 11 queries
