| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
I rewired it from the cartridge end thru the S shape and now its stuck at the counterweight end. How do I bring the wires down the narrow vertical column?
It seems I need to remove the S shaped tube but how can I do that? Tom |
#12 |
the wires are prob stuck at the horizontal bearing entrance
just below the s shaped tube you mention...its near getting into dismantaling the bearings now what thickness of wire are you rewireing with? maybe its to thick? maybe your jiont onto new wire is to thick? normally i isolate the earth internal wire ..and solder a new thin wire onto the 4 signal wires and pull thro...this gives me a safety net,before i pull thru new wire .....its sounding like the bearings needed dismantaled to do this 1 job properly you havent given me any photos ...so its hard for me to advise you to go much further...i cant advise you to dismantal the bearings....have another look see if u can see anything with a bright light patience pays off big time best wishes j7
www.audioorigami.co.uk |
#13 |
Sorry I don't have a webcam here, but soldering a wire and pulling it thru just might work. Looks like each wire is about 28 gauge.
Tom |
| Who will mod my rega p2??(rewiring) | ncdrawl | Analogue Source | 0 | 16th November 2008 01:47 PM |
| Linear tracking tonearm vs. Pivoting tonearm | Don Nebel | Analogue Source | 1 | 4th November 2007 10:49 PM |
| rewiring a Sony PUA-286 tonearm | eidling | Analogue Source | 1 | 8th October 2006 06:43 PM |
| Rewiring speakers | greg7 | Multi-Way | 0 | 7th June 2003 02:45 AM |
| arm rewiring | Havoc | Analogue Source | 6 | 12th July 2002 07:58 PM |
| Page generated in 0.07600 seconds (69.52% PHP - 30.48% MySQL) with 10 queries |
