| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
hi guys
i was looking into how to build a cheap but good quaility brushless motor for my prototype DIY turntables ...and i found this http://www.audioorigami.co.uk/Floppy...pyDIYMotor.htm for only a few quid make a excellent project ...and total time to convert is a few hours cant be bad can it? any questions feel free to ask best wishes j7
www.audioorigami.co.uk |
#2 |
ive been testing the last week
i found that you can vary the speed controller input signals ...we can control the output giving 33 rpm and 45rpm and 78 rpm....FROM A SINGLE PULLY SIZE...with a simple variable restistior (<---thats a volume knob control for the less tecs)
#3 |
Nice wok. I've been thinking of trying the same thing...I'm off to pick up a couple cheap old floppy drives now.
Fighting the program since 1976. |
#4 |
How do you make the motor run when the drive is not hooked up to a computer ?
}=- W o o f -={ |
#5 |
pins 12 and 16 need be conected to the ground pins (all the odd number pins 1-3-5 etc) or -ve terminal of the 4 or 5volt battery
ill be doing a picture session on my web site in the commin days with the variable speed control fitted
#6 |
Interesting!
How strong is this motor? What do you plan to use it for?
I don't suffer from insanity, I enjoy every minute of it! |
#7 |
hi m8ty
Power from these floppy drive motors varies from unit to unit ...all seem to be able to pull inner and outer platters of standard weights ...e.g. linn / thorns etc You can hold the motor and stop it dead...the unit has built in stall control...reconnect power and it’s on again The main feature of concept here is that the power supply to drive the motor is a cell phone battery.... you have to spend a lot of cash to better a battery supply Plus the motor only uses a tiny current...they are very efficient And new type mobiles use lithium polymer and lithium ion batteries.... your phone charger can power your turntable basic pictures are on my web site ....more to follow this week best wishes j7
#8 |
Does it matter if you use a 3.5" or 5.25" floppy drive?
Tom |
#9 |
This is a project I´ve been waiting for! So damn cool (and cheap)!
Please finish the guide soon, Audioorigami, please I have a plinth, a Mayware formula4 mk3, Linn LP12 subplatter w/ bearing + subchassis and an Originlive platter. I am just missing a motor and control circuitry. I tried a couple of dc motors with LM317T, but the speed kept wandering ( so I thought "sod it" and put the almost finished TT away a couple of months ago).
unknown pleasures |
#10 |
hi tom
the new type floppys are what i have gone for ...simply coss they very easy to find infact the old 5inch floppys are much better because they used bigger stronger motors...its the same wireing to make them work ...and slightly more ma to drive them ...so yes the 5 inch type are even more perfect....again every manufacter has made its own types ...so half the fun is opening the unit to see these units are all negatively - triggered.... pins 12 and 16 are conected to the - of the battery pins 1-33 are all - as well....you cant do the unit any harm with a 4 or 5volt (mobile phone )battery...so dont be scared to try out things the 12volt circuit is not needed in our use ...only the 5 volt side 12v (yellow) and 5v (red)...although a 12v battery could be used if you wanted with a drop down 5v regulator i will have some time to photo my test unit with vary speed and wireing ill post tonight so get out and grab some junk out your bin ![]() best wishes j7 ]
| Help required for using a FDD motor as a turntable motor. | binspaul | Analogue Source | 5 | 13th May 2009 03:59 AM |
| Lambda motor vs. XBL^2 motor vs. any other motor | Thinkcat | Subwoofers | 16 | 23rd December 2008 06:23 AM |
| Linear motor tracks for easy ribbons | tade | Planars & Exotics | 1 | 21st January 2008 05:27 PM |
| DIY TT: motor, motor PS, platter speed measurements | dice45 | Analogue Source | 52 | 9th May 2006 01:07 PM |
| is it really this easy? | MEGA-amp | Pass Labs | 4 | 2nd August 2005 01:55 AM |
| Page generated in 0.11005 seconds (80.05% PHP - 19.95% MySQL) with 11 queries |
