Old 29th January 2005, 07:11 PM   #1
Dimitar Kyuchuk's Avatar
Default Is there a better signal-sources switch than tda1029?
Hello, friends!
Do anybody know a better electronic signal-sources switch than tda1029? (I prefer not to use digital IC-s.)
Thanks in advance!
Old 4th February 2005, 09:50 PM   #2
rho is offline rho  Belgium
I'll be using SSM2404's in my pre-amp. (not finished yet.)
Maybe that's an option?
Old 4th February 2005, 10:00 PM   #3
Bill Fitzpatrick's Avatar
A high quality rotary switch is just the ticket.
Old 4th February 2005, 10:03 PM   #4
mcs is offline mcs  Denmark
Omron G5V-2? Or something similar from your favourite surplus dealer?
Best regards,
Mikkel C. Simonsen
My personal electronics website
Remote control kits website
Old 4th February 2005, 10:56 PM   #5
johnnyx is offline johnnyx  United Kingdom
I use relays too, so I second that. I use type 47 telecom relays though, the pin spacing is larger so tracks can easily pass between them. Be sure they have gold contacts, suitable for low level switching.
audio signal activated switch circuit needed setmenu Everything Else 6 3rd October 2007 06:17 PM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 09:24 AM
How do I turn an high current signal into a line level signal?? sardonx Tubes / Valves 8 27th August 2005 11:16 AM
Creating a differential signal from a single-ended signal for bridged amps Peter Daniel Chip Amps 45 8th November 2004 12:47 PM
Power switch sources?? Rolloatm76 Solid State 5 6th April 2001 10:44 PM
Page generated in 0.08376 seconds (71.62% PHP - 28.38% MySQL) with 10 queries
