Old 16th April 2005, 11:12 PM   #61
naz is offline naz  United States
Send a message via AIM to naz
Sweet thanks maxw for the suggestions, gives me something to play around with instead of starting from scratch on my on dual opamp design
Naz
Old 18th April 2005, 02:42 PM   #62
rjm is offline rjm  Japan
Richard Murdey
rjm's Avatar
To the beta-testers particularely,
I worked on the layout a little to incorporate some of your suggestions.
1. Bigger resistors can be used. 12.5mm spacing, type 0309, which I take to be 1/2W. Of course smaller ones can be used in the space.
2. Optional use of a film output coupling cap. Model shows Wima MKP4 22.5mm lead spacing.
3. The RIAA caps shown are WIMA FKP2, Probably the MKP or MKS series are a better fit from a package dimension point of view, being thinner.
4. Bypass caps shown are Panasonic FC, 25V 100uF. Since I know many of you want to add more capacitance, I`ll see what can be done here. I was going to make the lead spacing 3.5mm on the input at least, but putting the metric component in my 0.1" grid was not pretty, so I left it for now.
5. While I dont think moving the regulators off the board is a good idea, it can easily be made an option, just by bridging the in and out voltage traces of the unused regulator socket holes.
6. After all that messing about, however, the board size is now 3 inches square. Choice doesn't come free...
Richard
Old 26th April 2005, 01:47 AM   #63
Richard Murdey
rjm's Avatar
Default Phonoclone Beta Final Version
In case those of you who didn't sign up for the Beta-testing program are wondering how it came out. The boards, which will be made by Olimex, will be exactly half a eurocard, or 10x8cm.
-R
Old 29th April 2005, 12:49 AM   #64
Richard Murdey
rjm's Avatar
A couple of people have emailed me asking if PCBs are available.
The answer depends on the date you read this. I am taking orders until Saturday, April 30th, 2005. I will only have as many boards made as there are orders, so please don't email me later asking if any are left over because there wont be.
-R
Old 2nd May 2005, 01:10 AM   #65
Hey RJM?
Aaaah, forget it...
As is usual in my life, I'm a day late, dollar short.
Hopefully, another opportunity will come up again.
Old 4th May 2005, 04:56 AM   #66
Richard Murdey
rjm's Avatar
I'll let the first batch run its course before giving a definite answer, but given the level of interest chances are we'll do it again. Also giving serious consideration to a dual mono VSPS on 1/4 eurocard for $15/pair, but I'm getting ahead of myself...
email/pm if you want to be notified
-R
Old 8th May 2005, 03:32 PM   #67
steenoe is offline steenoe  Denmark
steenoe's Avatar
I am in
Steen
Old 10th May 2005, 01:48 PM   #68
Onvinyl's Avatar
Hi rjm,
on you website you state:
The impedance of the cartridge must be relatively constant over the audio band, however, or else the frequency response will deviate significantly from the manufacturers specification.
Do you - or anyone else-
happen to know which carts match your criteria, or vice versa, which not?
thx,
Rüdiger
Old 10th May 2005, 02:16 PM   #69
Richard Murdey
rjm's Avatar
Nope. Apart from the DL103, which I know is flat-ish from the little datasheet that came with it. But people with low output MC carts probably shouldn't be terribly concerned about the odd dip and rise in the response unless you're the type that calibrates against the load capacitance. More to the point I think is whether the resulting tonal balance works for you personally, or not.
Old 16th May 2005, 12:49 PM   #70
Richard Murdey
rjm's Avatar
Yay! Boards!
Phonoclone 3 rjm Analogue Source 719 12th April 2012 08:17 AM
WTB phonoclone boards c.d.s. Swap Meet 1 8th June 2008 09:04 PM
My take on the phonoclone Onvinyl Analogue Source 34 27th March 2007 02:11 PM
WTB: Phonoclone boards KT Swap Meet 0 20th February 2007 06:48 AM
Page generated in 0.12638 seconds (75.26% PHP - 24.74% MySQL) with 11 queries
