Old 12th January 2005, 01:47 AM   #1
resolution's Avatar
Default Lingo schematic
Does anyone have a schematic for a linn lingo.
I have the oppertunity to buy a dead one cheap.
regards
res
Old 16th January 2005, 11:39 AM   #2
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I'd be curious to see the diagram of a Lingo. But if you have a dead one in your hands, it wouldn't be difficult to trace the circuit. A turntable power supply isn't rocket science.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 18th January 2005, 04:02 AM   #3
andyr is offline andyr  Australia
I believe the Lingo is not the simple beast you might imagine from the name "t/table PS".
It's basically morphed from one of their power amps.
Andy
Old 18th January 2005, 06:05 AM   #4
analog_sa's Avatar
It took me a surprising amount of effort to draw a circuit off a simple Valhalla. Still, in the interest of science, if someone provides high-res pics of the Lingo i guess i'll do it.
Old 19th January 2005, 10:10 AM   #5
From the pics of the internals I saw it is no rocket science. A crystal oscillator using standard CMOS chips followed by an amp.
It should at least be easy to track down what is not working. The oscillator or the amp. So it depends on the price and your electronics experience if you want to take the risk or not.
Technically the Manticore MB6 is a much better design. It creates a stepped sine wave and has the phase shift done in the digital part or the circuit, not by a cap like the Lingo.
Have fun,
Frank
Old 19th January 2005, 11:15 AM   #6
analog_sa's Avatar
Does the Lingo really use a cap? It certainly has separate amps for the two phases and knowing how easy it is to get a second phase digitally generated (and at tunable angle) i find it difficult to imagine why use a cap.
Old 19th January 2005, 01:43 PM   #7
Well at least the old Lingo did to my knowledge. I'm not that sure if the old Lingo had two amps.
Manticore MB6 uses a CMOS shift register to make a stepped sinus (AFAIR a similar circuit is in the CMOS cookbook). Well it usees two shift registers oe for the sine and triggered from this one the second one for the cosine. Nice design.
C ya,
Frank
Old 19th January 2005, 03:06 PM   #8
EC8010's Avatar
According to Linn's home page, the Lingo uses one crystal oscillator for 33 and another for 45. The square wave is divided down and filtered to produce a sine wave which is then applied to a pair of Class A amplifiers, one of which is preceded by a 90 degree phase shift network.
Old 19th January 2005, 03:56 PM   #9
analog_sa's Avatar
'Phase shift network' should mean a capacitor. I wouldn't mind having one of these for couple of hours just to take a look at the amp stages. The synthesising can be done in a much better way these days. My prototype from almost two years ago used a microcontroller with a look-up table, two 8-bit dacs and filters. The sinewaves had very little distortion (almost as good as a Wien bridge) and phase shift could be chosen at random or 'by ear'. Still better would be to use a dsp.
How are this schematic ? rubydac Tubes / Valves 7 29th May 2008 01:17 AM
Lingo pcb connections el-folie Analog Line Level 0 20th August 2006 10:52 PM
Need a Schematic GreatWhiteHoke Solid State 5 21st November 2004 03:27 PM
help with schematic karma Tubes / Valves 3 27th April 2003 09:02 AM
New Lingo pk386 Everything Else 2 13th February 2003 06:01 AM
Page generated in 0.10998 seconds (68.84% PHP - 31.16% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
