| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Sorry if there are 2 post, I couldn't find the 1st one.
Anyway! Hi all, great site by the way! Now my problem. I am a complete newbie to turntables so my apology if this seems a bit simplistic! I have just got a pro-ject debut 2 and am having problems with the setting up of the anti skating weight. The manual states I need to bend the 'anti skating weight support hoop' as shown in the manual debut 2 manual but the diagram makes no sense (to me) and I don’t want to bend the 'anti skating weight support hoop' to far. Does anyone have a pic of how it should be done? A downforce tool??? was also supplied but no reference is made in the manual, how does this work? i.e. where do I put it?? Any help would be greatly appreciated Ross |
#2 |
#3 |
Thanks for that moamps, i'll give it a go!
#4 |
I wanted to post a new thread. Kept getting prompted to check the forums first. This must be the place I guess.
Every method of anti skate involves some compromise - no? Wouldn't the most accurate and fully uncoupled strategy be to simply tilt the turntable? Perhaps develop a chart with degree of tilt corresponding to stylus pressure or effective tonearm/cartridge mass or some combination? I'm hoping someone can explain the physics of why this is a bad idea. |
#5 | |
Took me ages to work out also Bluebeard but there is a tick box you have to click in to say you have checked the forums. It's in the top left of the page where you create a new thread and says Have you Searched? Can't answer your other question for you though! |
#6 |
Hi, if you tilt the whole turntable a little, you can certainly get a side force on the arm, but won't it be constant across the whole of the record?
Most of the antiskate designs - the Rega magnets, string-and-weight or more elegant ones like the Graham pivoted weight allow the force to vary as the arm crosses the record. I guess that this is not exact as maybe the precise amount of force needed will also vary as the tracking error goes down-up-down-up across the record, but it can be pretty close. regards, Jeff |
#7 |
In tilting the turntable you're assuming that the arm is unbalanced in the left/right plane. It may not be. Some arms are designed to be dynamically balanced in all planes. Conversely, a unipivot would certainly object to it and the turntable being tilted - it would almost certainly yaw.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| EMT 929 anti-skating weight | wpod | Analogue Source | 4 | 19th February 2008 11:20 PM |
| Thorens 166mk2 anti-skating weight. | unitgain | Analogue Source | 6 | 29th January 2004 12:41 AM |
| What does anti-skating achieve? | bm_mode | Analogue Source | 5 | 17th August 2002 06:17 AM |
| Page generated in 0.10175 seconds (65.05% PHP - 34.95% MySQL) with 11 queries |
