| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#21 |
Hi, does anyone have a copy of the Garrard 301 dwg or dxf that they could email me?
I'm an architect and am designing myself a hi-fi cabinet with a Garrard plinth on the top of it. I've attached a copy of my preliminary design in case anyone's interested. Any tips would be much appreciated. Has anyone any knowledge of the ply plinths and the best ply to use to get good acoustics and also a nicely faced finish? I'm planning to make the interior of the cabinet adjustable with removable shelved that slot into grooves in the side of the cabinet and are screwed into place. Any tips on isolation/ support would also be much appreciated - I'm thinking of using Vibrapods under the plinth and spikes to the base of the main cabinet. http://www.vibrapod.com/ Please email me on my members email or alternatively at: applebysteve@yahoo.co.uk |
#22 |
Welcome to the forum, sappleby.
I made the plinth (and arm) for my 301. The main thing you need is mass. At least 20kg. Cut the top sheet to the Garrard template, then make the succeeding cut-outs only as large as necessary (that first cut-out has to be large because of all those levers, but the others can be much smaller). This will make the plinth much stronger and heavier. I would suggest using lead flashing to increase the weight and damping (as I did on my plinth), but that's probably illegal now. Read through this thread to see other tips.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#23 |
sappleby, you've got mail.
Can't tell very much from your drawing. Like the cabinet, though. If I would redo my plinth today I would make it out of concrete, with a machined piece of aluminium as bottom "plate." Love Tando Ando's stuff. ![]() I spent at total of €4 on my rubber feet. |
#24 |
Hi
And now for something completely different: http://www.blueangelaudio.com The size is w49xd40xplinth thickness5cm and the weight 27kg. This is the 12th year since I made it. bulgin |
#25 | |
Any discounts for DIY Audio members ![]() Thanks! |
| dual turntable mounting template | PTSOUNDLAB | Analogue Source | 5 | 27th February 2010 02:04 AM |
| LTSpice Simulation template?! | ipop07 | Tubes / Valves | 5 | 13th May 2009 07:17 PM |
| Garrard 301 and SME 3012 plinth template | ozval | Analogue Source | 2 | 14th January 2009 06:56 PM |
| Ariel template, free to good home | chrish | Multi-Way | 0 | 14th June 2008 02:21 AM |
| DIY Tonearm Mounting Template ??? | PlatterMatter | Analogue Source | 8 | 13th September 2007 07:01 AM |
| Page generated in 0.10032 seconds (65.21% PHP - 34.79% MySQL) with 11 queries |
