Old 19th December 2004, 10:23 PM   #41
Kofi Annan's Avatar
You might want to look into something like a "Platter Matter" to replace the original mat at some point.
Asked for and may receive a new mat / record clamp for Christmas.
Don't forget to correct the vertical tracking angle if you change mats.
Uhhh... I uhhh... really haven't aligned the VTA. I'm just kinda eyeballing it right now. The cartridge is aligned properly and the table is balanced, to the best of my ability, but the VTA... well... still need to do that.
Is it worth investing in one of those Rega VTA adjsuters? Will I destroy my record collection and rob myself of enjoyment if I don't meticulously adjust the VTA until later?
Kofi
Old 19th December 2004, 11:26 PM   #42
anatech is offline anatech  Canada
anatech's Avatar
Watch out for the ghosts of vinyl past. I think if you are in the ball park with VTA then you are fine. At least the cartridge isn't 15˚ off center ... is it? Have a great holiday!
-Chris
Old 14th May 2005, 12:32 AM   #43
rkay5 is offline rkay5  United States
rkay5's Avatar
Default Thoren Troubles
Ok Kofi I was reading your post today about your TD160 as I have had a 160 a TD146 and now I have a Thorens TD150mkII,you say that your table runs fast and faster with a new belt .Thorens belts are to tight it should be a total of 520mm to 530mm in lenght so what I did is put the belt on a 12" ruler overnight or for about 24 hours and that will help you also can adjust tilt of motor and you can get the speed right on also you can us a out board psu that is what I'm using a Project Speedbox .Now on to the tonearm on my TD150 I us a Rega RB250 that I got on ebay for $179.00 new 1 1/2 years ago I see RB250 on Audiogon all the time for $229.00 witch is a very good price
and for the money a very very good arm I love mine ,Hope as help Robert
Old 14th May 2005, 07:18 AM   #44
planet10's Avatar
Default Re: Thoren Troubles
Originally posted by rkay5
RB250... a very very good arm
and even better tweaked up...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th May 2005, 04:13 PM   #45
Kofi Annan's Avatar
I figured out that you could adjust the tilt of the motor to adjust the speed, so things are definitely better, but still not perfect. I'll eventually splurge for an outboard TT motor, but I've got my hand in a speaker project right now (Swan D-101a). Couple that with some work issues that need attention (Iranian nuclear proliferation) and I've become a busy man.
Thanks for the reply!
Kofi
Kofi Annan in: "Kofi's Living Room" Kofi Annan Full Range 5 25th May 2008 06:19 PM
Kofi Annan in: "Kofi Makes a 300b DRD... and You Get to Help!" Kofi Annan Tubes / Valves 135 15th October 2007 07:15 AM
Kofi Annan in: "300beee!" or "Kofi Gets a Toy" Kofi Annan Tubes / Valves 125 25th August 2006 04:39 AM
Page generated in 0.09303 seconds (68.19% PHP - 31.81% MySQL) with 11 queries
