| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Hello,
I recently purchased a Shelter 501 and I'm about to start experimenting with cartridge loading. The Shelter manual states the DC resistance at 12 ohms, and suggests the recommended load impedance as follows. Step up trans within 20 ohms. Head apmplifier within 100 ohms. High gain EQ amplifier within 47K ohms. I will be using a (47K ohm) Hagerman Cornet phonostage with some Lundahl LL9206 step up transformers set at the 1:10 ratio with 20db's of gain. According to the specs above I could go down to within 20 ohms. I've done a bit of reading in the archives and it seems a lot of people are loading the 501's at around 100 ohms with various step up transformers. Can some of you kind folks tell me where you are loading yours, and maybe comment on the differents in sound above and below the 100 ohm norm. Thanks, Frank |
#2 |
I'm running it at 10 ohm (ortofon T20) and it sounds very nice (A lot better than my Sony SACD and also a lot better than my other cartridge AT-OC9ML )
| Info on Decca cartridge loading sought. | Aleksunder | Analogue Source | 6 | 30th November 2006 12:52 AM |
| 'fet as resistor' for cartridge loading? | Onvinyl | Analogue Source | 1 | 4th February 2006 03:08 PM |
| Anode Loading Vs. Cathode Loading ? | valveitude | Tubes / Valves | 19 | 22nd July 2005 10:00 PM |
| MM Cartridge loading question | gurevise | Analogue Source | 7 | 16th December 2003 12:30 PM |
| Cartridge Loading | vpharris | Analogue Source | 2 | 9th July 2002 03:40 PM |
| Page generated in 0.07995 seconds (58.89% PHP - 41.11% MySQL) with 10 queries |
