Old 7th November 2004, 12:26 AM   #1
Tony.ca is offline Tony.ca  Canada
Tony.ca's Avatar
Question anyone with diy turntable pictures?
hi there guys,
Anyone interested in posting their TT's pictures made or owned by them.
some thing like these?
Old 7th November 2004, 12:41 AM   #2
fcel is offline fcel  United States
Try this .... http://www.nakedresource.com/phpBB2/....php?cat_id=93
Old 7th November 2004, 06:10 AM   #3
skaloumbakas's Avatar
Default tell me some more, if you agree...
Tony,
Congrats, this is a very fine design for a diy t/t
I took the liberty and placed your t/t's picture in the turntables' section of the A.C.A.'s web-site (http://aca.gr)
Please look at: http://aca.gr/turntable_b.htm#diy and, if you give me permission, i will keep it there (just need 10 words of construction details, arm/cart on it and your or the designer's real e-mail)
If you do not agree or you want to use your pic for some other way, please, tell me to remove it.
In some time from now, all DIY t/t pictures in that page will be moved to a special section of out Photo Album (http://aca.gr/forum/album_cat.php?cat_id=2), where somebody can make comments below the pictures as well... )
Keep up with the good work
Old 7th November 2004, 02:19 PM   #4
Tony.ca's Avatar
skaloambakas,
You got it all wrong ,I just got this TT pic from the website I did'nt make it.(I wish).I just wanted to show an example thats all.
Apologize if I misguided.
Thanx,
Tony.
Old 7th November 2004, 03:16 PM   #5
Here is my DIY project in its recent state.
Old 7th November 2004, 03:45 PM   #6
Default When you are dealing with 200 t/t pictures...
Originally posted by Tony.ca
skaloumbakas,
You got it all wrong, I just got this TT pic from the website I did'nt make it.(I wish).I just wanted to show an example thats all. Apologize if I misguided.
Thanx, Tony
Ahhhh Tony,
You have confused me.
Funny thing is that i later discovered that i had been including this t/t in my Gallery a long time ago ( http://aca.gr/turntable_e.htm ) and it is not a DIY but the Transrotor Orfeo, w/ Audiocraft AC-3300 dual uni-pivot arm.
You made a foul out of me... but I am still loughing - no problem...
Old 7th November 2004, 05:06 PM   #7
rcavictim's Avatar
I've started building my own turntable. Here is the platter I made on the lathe. It is two 1-1/4" thick pieces of Lexguard laminated together. Weighs 14 lbs. IIRC. This is a back burner project with the other projects that are higher priority right now.
I.Q.Test. Have you ever purchased a recreational snowmobile?
Old 7th November 2004, 05:33 PM   #8
More pictures .... my DIY Turntables and DIY tonearm
Old 8th November 2004, 07:51 PM   #9
Alain Dupont's Avatar
rcavictim,
Beautifull platter. How did you "laminate" the 2 pieces ?
Question where is situated "upstate Ontario"
Regards.
Alain.
Old 9th November 2004, 12:37 AM   #10
rcavictim's Avatar
Originally posted by Alain Dupont
rcavictim,
Regards.
Alain.
Hi Alain,
Laminating was very time consuming. I cleaned the mating surfaces scrupulously. I mixed a small batch of that two part water-clear epoxy sold to replace 50 coats of varnish on counter tops. The product I used was made by Behr and called "Build-50". After mixing it in proper proportions I poured it into a large mouth drink bottle that was absolutely clean and pulled the bubbles out of it for a full half an hour with a mechanical vacuum pump. The stuff foamed for a very long time. Once it was outgassed I carefully poured it onto one surface of the pair and pressed the other piece on. I then applied clamp pressure and in the process, despite all my care, was horrified to see tiny bubbles appearing despite the vacuum pump work. I was able to squeeze the bubbles away with C-clamp pressure. I left the clamped assembly under clamp pressure for two days in the warm house before removing the clamps. I was then able to cut a circle on the bandsaw and mount the piece into my lathe to turn it.
This material does not have absolutely parallel walls and I had to face and polish one side to match the other. I also polished the OD. It came out very nicely and runs absolutely true.
Upstate Ontario is a cool place (highest altitude) NW of Toronto! If New York can have an area that is named to sound trendy, so can we. There is no 'Downstate Ontario", I guess the same reason there is no Downstate New York.
Pictures of my T-Amp. hsu Class D 5 14th February 2007 04:06 AM
Griffin Audio turntable and system (lots of pictures) Greg3333 Analogue Source 2 12th June 2006 12:33 PM
About me with many pictures... Lord_Magnepan Introductions 1 30th March 2005 04:28 PM
New SOZ with pictures! cjunk Pass Labs 40 2nd February 2003 07:52 PM
Page generated in 0.14673 seconds (69.33% PHP - 30.67% MySQL) with 11 queries
