Jean Hiraga Mc circuit
Old 24th June 2002, 11:02 PM   #11
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
As the circuit is conceptually similar to the Threshold M1,
and I have not seen another instance of common-base
MC amplification, I am curious. What do you have for the
date on this?
Old 25th June 2002, 12:06 AM   #12
lohk is offline lohk  Europe
lohk's Avatar
The orginal articles appered in L'Audiophile #16 June 1980 and #17 October 1980.
Btw. the possibly first One-Transistor-Amp called "Nemesis" (10W ClassA MOSFET with an output transformer) appeared in #34 and #35, winter and spring 1985.
Klaus
Old 25th June 2002, 05:47 AM   #13
jam is offline jam  United States
jam's Avatar
Default Common Base Head Amplifiers
Nelson,
Marshall Leach designed a common base headamp and published in Audio Magazine years ago.
http://users.ece.gatech.edu/~mleach/headamp/
PS Audio also used a common base headamp in their preamp, this also going back a few years. (In their case they converted the first transistor of the differential in the phono stage to a common base amp).
Jam
Old 25th June 2002, 05:52 AM   #14
jam's Avatar
Oops! Wrong image.
Here is the correct one.
Jam
Old 25th June 2002, 01:56 PM   #15
syl is offline syl  Sweden
The original question was alternate transistors for the Hiraga MC.
I did quite a lot of transtor swapping in the early 90s. It turned out that the C1775, A872, C2389 and B737 all gave too much "bite" to the music. Initially a sense of dynamics is perceived, but after some hours of listening it was not deemed neutral. These transistors put too much focus on the high frequency range.
The BCs I tried sounded just plain bad, distorting badly compared to the japanese transistors.
I stumbled across the A1038 from Rohm. That made a big difference. A beautiful midrange without the excess high frequency fuzz of the others. Far better than the Hiraga original. Highly recommended.
Eqvivalents are A1579(smd) and A1514(smd).
Syl
Old 25th June 2002, 04:04 PM   #16
tvi is offline tvi  Australia
tvi's Avatar
<a href="http://www.hilberink.nl/amps/amps.htm">www.hilberink.nl/amps/amps.htm</a> show the schematic I posted earlier
and and has this:
<font color=#800040><i>Below a evaluation of the original design of Hiraga of 1988. This design has all the advantages of a modern well riped design but lacks some limitations of the basic Hiraga design. As far as I know this design was never published in this form, a very similar design was published in Elektor. </i></font>
<a href="http://www.hilberink.nl/amps/amps7.htm"><img src="http://www.hilberink.nl/amps/hiraga4.jpg" ></a>
<font size="-2">pic a link</font>
James
Old 15th February 2013, 09:02 AM   #17
noyan is offline noyan  Turkey
Send a message via Yahoo to noyan
Default My Hiraga MC preamplifier
Firstly i built a very successful MM preamp. I modified the Audionote M7-M10 schematics. Now, it use 4*6072+2*6N30P-DR. Sounding incredible natural, sweet and detailed. Then i decided to built a Hiraga MC pre with 8 pins IC sockets on main board. I prepared (soldered) 2SA1038 and BC560 transistor pairs on seperate 8 pins sockets. Now, i can easily insert any of them in the sockets located on the board and compare the sound. Before this off course i am making adjustments with trimpots to ensure ''0'' Volt at the enter of the preamp. I can say that; this preamp and DENON 103R is sounding excellent with both transistors. But, my favorite is 2SA1038 -Thanks syl- I used 500.000uf capaciy for each channel. Electrolytic caps are 6800uf Elna Cerafine, cables are teflon coated silver. I will install a power switch and a socket for charging the batteries.
Noyan
Old 4th April 2016, 09:28 PM   #18
simonbring is offline simonbring
Excellent mc preamp you have built Noyan! Do you have schematics on your construction?
Old 3rd November 2017, 03:31 PM   #19
m0rten is offline m0rten  Norway
Send a message via MSN to m0rten
Default Hiraga MC etc
Hi!
I build this Hiraga MC amp many years ago. Not very elegant, but it worked quite well.
I guess it still does, except that the accumulators are probably dead by now.
With the power switch in ON position, the mains is OFF.
In OFF postition, the mains is ON, causing the accumulators to trickle-charge.
The project was from a reprint in a Swedish magazine in the '80s.
Schematic, box and PCB
;-) morten
Old 3rd November 2017, 03:40 PM   #20
Default The "etc"
My second MC amp was from WW, also in the 80's. Looks like a Leach clone, or cloned by him, I don't know.
Anyway, it works really well and I used it for a few years.
Schematic, board layout and specs
;-) morten
Jean Hiraga Mc circuitHide this!Advertise here!
Jean Michel on LeCleac'h horns angeloitacare Multi-Way 1792 4th September 2017 09:39 PM
Jean Hiraga RIAA Phono icefox Analogue Source 25 23rd August 2013 08:45 PM
Copyright ©1999-2017 diyAudio
