Modified RB300 & Goldring 1042
Old 19th September 2004, 04:35 PM   #1
carl loller is offline carl loller  United Kingdom
Question Modified RB300 & Goldring 1042
I want to get my RB300 arm on my Rega Planar 3 modified by Origin Live and then fit a Goldring 1042.
Will I need a VTA adjuster fitted to the arm base get the 1042 catridge rake angle correct?
Anyone out there done it and got some advice/tricks on how best to do it?
Old 20th September 2004, 05:33 PM   #2
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Goldring an Rega...
if my memory serves me correctly Goldring builds the Rega cartridges. THe Rega MM cartridges and the Goldring cartridges share the same body. No VTA spacers or adjusters should be required, as per Mr. Gandy's wish.
Old 20th September 2004, 08:18 PM   #3
Raka is offline Raka  Europe
Raka's Avatar
I have now a RB250 with the 1042. Sounds good, but the resonance is a bit low (less than 10Hz in my case).
What is beyond the speaker?
Old 21st September 2004, 09:59 PM   #4
Thanks for both answers - I didn't know Goldring built the Rega cartridges but it sure solves the problem if the shells are the same size.
I think I will buy the Goldring 1042 now given your comments.
Cheers
Carl
Old 23rd September 2004, 03:38 PM   #5
Toaster is offline Toaster  United Kingdom
The Goldring 1042 seems fine on the RB300- but the bodies of the Rega cartridges are not identical to the Goldring 1000 series. Of course the height might be the same anyway...
Old 25th September 2004, 01:38 PM   #6
KKG is offline KKG  Singapore
Dear Nanook
Re: "if my memory serves me correctly Goldring builds the Rega cartridges. THe Rega MM cartridges and the Goldring cartridges share the same body"
Have you ever seen these MM, Rega & Goldring, cartridges side-by-side? Or, even their pictures over the net? They do not bear any resemblance. Besides, the Rega has three holes for mounting and the Goldring has only two.
Please look at these cartridges at their respective websites -
Rega Cartridges -
http://www.rega.co.uk/index2.htm
Goldring 1042
http://www.phonophono.de/english/htm...details_9.html
As far as height of the two series, Rega and Goldring 1000 series, are concerned, they are about the same and you'll not need any VTA adjustments.
IMO, if the prices are about the same or thereabout and you do not have to stretch too much, get the Dynavector DV105X (or whatever their #). Your MM phone stage can handle this cart as its a high output one and it'll, imho, give you better value for your hard earned $ then either the Rega or Goldring.
Cheers
Old 5th October 2004, 05:24 AM   #7
Nanook's Avatar
Default goldring cartridges...
er was it the Roksan Chorus Black and the Goldring...
Modified RB300 & Goldring 1042Hide this!Advertise here!
Goldring GR 1.2 revisited? Sella Analogue Source 5 2nd April 2012 01:28 AM
Modified Ratshack 40-1042 Openbaffle larc99 Full Range 0 2nd February 2008 05:04 AM
Rega mods possible for a goldring gr1.2? Dancing_Priest Analogue Source 3 10th January 2008 09:41 PM
Goldring Lenco alexandros1970 Analogue Source 3 15th March 2005 07:39 AM
Tangband W69-1042 Groupbuy Lusso5 Swap Meet 0 12th January 2004 08:25 PM
Copyright ©1999-2017 diyAudio
