TT ground Question
TT ground Question
Old 16th September 2004, 07:42 PM   #1
Deacon_808 is offline Deacon_808  United States
Default TT ground Question
OK, I recently bought 2 DJ style TT's, Gemini XL-500mk2's, theyre Technics 1200 knock offs. They both work great, except one has a 60Hz hum like a mofo. I know how to ground them, Ive tried every thing I can think of. So I opened it to look inside at the ground post, every thing looks fine, no broken wires, BUT, There is no wire soldered to the ground post of the incoming power cord. My question is twofold, 1) If I connect the ground post of the incoming power cord to the ground post next to the RCA outs, will that eliminate the hum, and 2) If not, will that F something up?
Thanks in advance for any advice.
BTW, I love this site!
Old 17th September 2004, 11:48 AM   #2
Havoc is offline Havoc
First check if there is continuity from your ground point to the arm and shell. The wire may be broken inside the arm.
Old 17th September 2004, 11:52 PM   #3
Okay
Old 29th September 2004, 05:59 PM   #4
satyr19 is offline satyr19  United States
Send a message via AIM to satyr19
Ive seen an audio shop put on a cartridge on my turntable and the first time it hummed really bad because of a bad connection of the wire clips to the cartridge itself. Try playing with those.
TT ground QuestionHide this!Advertise here!
Ground Bus question KT Parts 0 28th March 2006 02:09 AM
GC PCB Ground Question Gcollier Chip Amps 0 18th June 2004 11:08 AM
Pin 7 to ground question for IGC Stever Chip Amps 6 8th November 2003 07:57 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
