Which TT do I use as a donor for DIY TT? - diyAudio
Old 13th September 2004, 03:25 AM   #1
G is offline G  United States
G's Avatar
Default Which TT do I use as a donor for DIY TT?
Hi All,
I have a project (yet another one) perculating in the back of my mind> I would like to use a old TT for parts to build a DIY TT. By parts I mean the motor, the platter bearing and the platter. Which TT would you use for parts? Thorens? Dual?
Gavin
Old 13th September 2004, 04:43 AM   #2
Illusus is offline Illusus  Canada
Illusus's Avatar
If it was a choice between Thorens or Dual... i'd pick the Thorens. I have built both. One from a Thorens TD160 and one from a Dual 505.
Although the Duals can be had for much cheaper, the motor, platter and bearings are inferior to the Thorens...I can't speak for the 12xx series though. My last DIY TT was built from a Rek-O-Cut, the bearing and platter are very robust, the bearing is very quiet. The old rec-o-cut tables show up on ebay often, although sometimes overpriced, it's a crap shoot with them. They also come with a very large and quiet Pabst motor. Just check ebay often, you might stumble accross some parts you're looking for, every once in a while a VPI(or something similiar) platter and bearing show up, I just missed a set that went for under $200.
Good luck.
Fighting the program since 1976.
Donor DVD player for DIY project smallangryboy Digital Source 3 29th December 2009 11:08 PM
Donor H/K A224 Amp VeeDub Tubes / Valves 3 1st May 2007 08:47 AM
Copyright 1999-2017 diyAudio
