| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#11 |
Hey Mark,
I am aware of the screws under the Plinth/platter for adjustment, and had did it before on my other model. Problem is I forget some little things over 4 years of not having it. I seem to recall having mine being able to float with a lot more range and looking through this one I can't see anything that should be restricting this. Of course I can loosen up the suspension with just a Phillips type screw driver for the suspension. The legs balance totally on their own and just a basic 3 point balance system. Also I emailed the seller to see if he placed something in the suspension for transport but at the moment I have heard nothing. Either way still a few steps before its all up and running correctly. |
#12 |
Make sure that your belt and motor spindle are free of any kind of oil from touching them with your hands.
Also make sure your belt tension has not been reduced by stretching due to age. These become more of an issue with heavy platters some use. Many moons ago an Ariston I had did this and cleaning and tightning the belt cured the speed variations Regards David |
#13 |
These can rot and pieces can stick within the coils of the springs. If the springs are suspect I would suggest either new springs, or a much less expensive alternative, such as suggested on user510's site ( search for the analog dept. on the Interweb).
stew ☮ -"A sane man in an insane world appears insane." |
| Story on Wow - Flutter correction | Pano | Analogue Source | 4 | 3rd March 2013 03:56 PM |
| Systemdek llX | Jazzcat | Analogue Source | 3 | 12th October 2008 04:11 AM |
| how to? simple wow/flutter measurement | Steerpike | Analog Line Level | 14 | 27th September 2008 07:45 PM |
| Using wow and flutter meter | JesseG | Parts | 7 | 6th March 2006 01:10 AM |
| Wow and Flutter Meter 4 Sale | Bill Fitzpatrick | Swap Meet | 1 | 16th June 2005 04:55 PM |
