| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
#91 | |
OK,... so I blew it in my first post, not realizing that the photos could not be seen if you were not a member of taperssection.com
Here are a couple of photos, and, the photobucket pic folder for the set: ![]() ![]() from this album: http://smg.photobucket.com/albums/v1...M%20by%20Moke/ this is the text from my original post at the other forum: Quote:
#92 |
finally got the kick in the butt to finish this oft-delayed project.
tada! ![]() not much of a looker but it sucks pretty good. except for some minute traces of liquid deposited very near the record's label, it works quite well. a couple of things to be improved; a better looking wand and end-cap record clamp replace blu-tack with something better hehe ![]() record cleaner porn thanks for the inspiration guys!
#93 |
Hey Kimmy, it looks great! I love the use of the little cupboard, at least you can get to your bottle (though if it's like mine it'll probably only need emptying about once a decade
and somewhere to keep all thise brushes, pads bottles etc that seem to collect around mine. Nice pump too, what is it?Have you powered your turntable? If so tell us about it, as while i don't feel the loss at all, indeed quite the opposite, I keep feeling I *should* power mine and it would be fun to do And if you haven't how are you turning it? All the best Graham |
#94 |
hi graham, thanks for the compliment!
the cupboard-type enclosure was done out of necessity, unfortunately . i initially planned on having a pullout drawer below the cupboard door to hold the record inner sleeves. now i wish i had done so the vac is of a piranha brand (sorry, no box or model number as i got it from a thrift shop). it pretty much look like this... http://cgi.ebay.com.au/ws/eBayISAPI....m=190246218773 the platter is hand spun hehe, no motor yet. it would be nice to have though ![]() you were right, it might take a decade before the bottle gets filled up. after cleaning a couple of lps, i can barely find traces of crud or liquid in the slop bottle. one caveat though, this vac screams thinking of padding the insides of the cabinet with foamy material, hoping to lessen the noise. regards
#95 |
Matt,
Do you have the model number of the Poineer turntable you used? I want to use your exact set up as I have a motor that will work perfectly. I have had a hard time finding a turntable that has the platter spindle setup like the one you used. Any info would be appreciated. Thanks, Dave |
#96 |
Just came across this thread -- very beautiful work here. I thought I would add a couple of recipes for record cleaning fluid that I've used............
Stock solution: 80% (by volume) distilled or deionized water 20% (by volume) isopropyl alcohol To each quart/liter of stock solution, add: Recipe 1. 10 drops of Kodak Photo-Flo 200 4 drops of regular blue Windex ----or--- Recipe 2 20 drops of Kodak Photo-Flo 200 3 drops of regular blue Windex Recipe 1 is from Cordesman in The Absolute Sound many years ago. Recipe 2 is from Audio Asylum and claimed to be same as VPI cleaning fluid. My local pharmacy will order 99% isopropyl alcohol for me so that's what I use. Don't use stuff labeled rubbing alcohol as that might have other chemicals in it, but that's probably well-known to most here. Phil |
#97 |
Lots of cool looking machines in here. Right now I am just using a modded shop vac attatchment with a VPI cleaning brush, and an old turntable I found at the side of the street with a cork matt on it.
I made the cleaning fluid out of 99.9% iso alchohol (had a mom and pop drug store order it for me), distilled water (not lab grade but if I can find some pure water I will use it), and a drop of Triton X-114. Bought a bottle of it here that should last me a long long time http://chemassociates.com/shopsite/Chemassoc2/ Anyway the tables you guys did look cool. Might have to keep an eye out for the perfect table at the thrift store and maybe order that VPI upgrade set. I've been told never to use photoflow as it will leech your vinyl. |
#98 |
Yes, some cool record cleaners here! I just picked up a Kenmore magic blue vac for $5. Got a few old TT's I can use as cleaning platters- probably do the hand method.
I have also been researching cleaners. What I keep hearing mentioned on threads in sound archival circles (ARSCLIST) is Tergitol, namely Tergitol 15-S-3 (oil soluble surfactant) and 15-S-9 (water soluble surfactant). Found some for sale at Talas; ~$20 a pint for each. Sounds pricey, but then you realize you only use 0.25 parts of each in 100 parts deionized water!! I would bet most of the $$ record cleaning solutions out there use this stuff. Anyone here tried it? More info- go to bottom of this link- http://www.vinylengine.com/care-and-...aterials.shtml If it's good enough for the National Library of Canada AND The Library of Congress, it's good enough for me! I have also seen the 'Disc Doctor' stuff recommended on the ARSCLIST as a good ready-made cleaner. -Kent |
#99 |
Yeah think most LCD and record cleaners are usually
water (deionized and distilled) alchohol nonionic surfactant (a drop or two not enough for it to start sudding) |
#100 |
Oh, and something I have also noticed on the archival posts- Kodak Photo-Flo is not recommended. You will need to thoroughly rinse your records w/ de-ionized water if you do. Best not to go there, in my opinion. Kodak mentions not to use it for this purpose.
| I made myself a record cleaner | Sclalars | Analogue Source | 206 | 2nd May 2012 10:12 AM |
| When a Kenwood record cleaner-to be becomes a Garrard 301/Thorens TD124 Hybridmonster | honinbou | Analogue Source | 20 | 28th October 2011 09:48 AM |
| Ultrasonic Record Cleaner- any feedback | Ianmac | Analogue Source | 6 | 12th October 2011 07:10 AM |
| DIY Record Cleaner Machine | cactuscowboy | Analogue Source | 19 | 3rd August 2009 05:15 AM |
| Inverting rotation of a VPi record cleaner | m.parigi | Analogue Source | 4 | 29th October 2003 08:11 AM |
| Page generated in 0.16457 seconds (86.98% PHP - 13.02% MySQL) with 11 queries |
