My DIY record cleaner.
Old 18th August 2004, 08:15 AM   #1
mattjk is offline mattjk  United States
Default My DIY record cleaner.
Finally got around to building this thing.
I bought the VPI 16 to 16.5 update kit, which consists of the suction tube assembly, and a dust cover.
I then went to Target and picked up a Furio file cabinate/coffee table.
The Pro-ject RM4 turntable will go on top, and then the middle shelf will be used for the record cleaner. The small shop vac will go in the drawer, so it will be hidden... that is the nice thing about this stand, is that all the junk can go in the drawer and be out of site.
Here you can see the vpi suction tube mount and the pioneer spindle and bearing assembly installed on the middle self.
Here is the suction assembly and turntable platter installed.
All I need to do now is connect the vacuum hose to the vpi suction assembly and it will be ready to use. For now I'm just going to turn the record by hand... later I may install a motor.
Matt
Old 18th August 2004, 11:22 AM   #2
Ropie is offline Ropie  United Kingdom
Ropie's Avatar
Excellent!
Old 19th August 2004, 07:23 PM   #3
Thanks!!
Old 19th August 2004, 07:34 PM   #4
VT67 is offline VT67  Belgium
VT67's Avatar
Very nice indeed!
Walter
Old 19th August 2004, 08:25 PM   #5
earsandeyes is offline earsandeyes  Netherlands
earsandeyes's Avatar
Default What shop vac are you using
Very smart.
What type of small shop vac are you using?
Capacity wise. The few I am aware of in the netherlands are or to expensive or just doing volume.
Please advise details
Old 19th August 2004, 08:48 PM   #6
jimrick1 is offline jimrick1  Canada
Terrific looking RCM! One of the VPI RCMs has a switch to reverse rotation of the platter, so you can clean records in both directions. If you do not mind turning the platter by hand, you can clean in both directions, too. I bought a used 16.5 with broken motor a few years ago. Turning the platter manually has never been a problem, and I like cleaning in both directions. The VPI motor turns the platter at 18 RPM, don't know if faster rotation will work or not.
Old 19th August 2004, 08:50 PM   #7
Thanks!
It is the Shop-Vac model 1x1
http://www.shop-vac.com/web/products...index&StoreID=
Cost $19 usd from Walmart.
Old 19th August 2004, 09:02 PM   #8
Here is a rough costs breakdown.
Stand. $59 from Target.
Platter and Spindle. Used direct drive Pioneer turntable from eBay. $10
VPI 16.6 suction tube and mount. $59 from www.elusivedisc.com
http://www.elusivedisc.com/prodinfo....em=23&mitem=29
Shop-Vac 1x1 $19 from Walmart.
I already had the turntable and shop vac laying around... so it was even cheaper for me.
Old 19th August 2004, 10:26 PM   #9
mlloyd1 is offline mlloyd1  United States
mlloyd1's Avatar
Very nice work! I think I see a project coming up in the near future ...
mlloyd1
Old 20th August 2004, 07:09 AM   #10
Got the vacuum hooked up.
I found a small parts box and drilled a hole in it to fit the attachment pipe that came with the shop-vac. I cut it down to size, and glued it to the parts box with plastic plumber's cement. I then bolted the parts box to the underside.
The shop-vac was a bit too tall to fit in the drawer, standing up, so I made a little adjustment to the floor of the drawer. I basically removed the drawer, put it on the ground and just put my foot through it! It dislodged the front of the floor and pushed it down just enough! perfect fit.
I also found a perfect application brush. Got it at the 99cent store, and it is very soft and fine bristled. Perfect for this application! It is made for polishing leather shoes.
I cleaned 4 records tonight, and it works fantastic!!!
The record is very easy to turn, but I still want to install a motor drive... just have to find the right parts.
Matt
My DIY record cleaner.Hide this!Advertise here!
I made myself a record cleaner Sclalars Analogue Source 231 20th February 2017 06:01 PM
When a Kenwood record cleaner-to be becomes a Garrard 301/Thorens TD124 Hybridmonster happycat Analogue Source 40 4th August 2015 08:27 AM
Ultrasonic Record Cleaner- any feedback Ianmac Analogue Source 7 13th November 2012 04:28 AM
DIY Record Cleaner Machine cactuscowboy Analogue Source 19 3rd August 2009 06:15 AM
Inverting rotation of a VPi record cleaner m.parigi Analogue Source 4 29th October 2003 09:11 AM
