| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
Banned
Id like to know if there is any one that has a regulated psu schematic out there for my amp. The amp has voltage rails of 45V+ 0 45V- I was told that having a steady accurate psu for my power amps would be a little better as im learning to work on psu's.. i was also told that the regulated psu is basically like a power amp feeding a power amp. is this true.. the amps are small and are really fast clean simple amps.. my so called favorite blue amp's.. Can any one help me ? the psu so far has a 500va Toroidal transformer but i will be buying another to make these mono block's.. thanks
J' |
#2 |
Banned
#3 |
if you must regulate -- the easiest way of doing it for high power and high voltage positive and negative is with the LM317HV and LM337HV regulators PLUS an outboard pass transistor -- National gives an example on their site for the LM317HV -- you can also use the lower voltage versions of these regulators and lift the "ADJ" terminal off the ground with a zener diode.
this isn't the most elegant solution, but it will work. |
#4 | |
Change Z1 and Z2 from 12 to 9.1V/1W to get output voltage around 40V from original schematic. Regards Milan |
#5 | |
Banned
Ill look into this.. maybe get a friend to help me design the board since he is good at them : O ) any thing else i can do before laying out a board. ? |
#6 | |
Use output transistors with high beta at high output current. Input voltage must be ca 10V higher than output (55 in, 45 out) without load. Downsize R1 and R17 (4k7) to ca 3k3 or so. (same zener current at smaller Vin (from 80 to 55). Regards Milan |
#7 |
Banned
oohhh ok.. i was goiing to keep the original psu and use this infront.. but that is ok i canget new tranny's..
Now ami still useing filtering cap's Before or after this regulated psu ? I think it would be after Am i correct ? |
#8 | ||
Regards Milan |
#9 |
Banned
The Original PSU sounds great but i want to tinker and if i build one for one channel and see if there is a difrence or not...
#10 | |
| Regulated PSU?? | MikeFarad | Solid State | 4 | 12th July 2007 10:41 PM |
| Regulated or non-regulated SMPS | longitude | Class D | 5 | 8th May 2007 03:02 PM |
| Need a little help with my first regulated PSU | jarros | Power Supplies | 16 | 2nd May 2005 11:28 PM |
| Regulated PS Kit | cantskienuf | Chip Amps | 7 | 24th September 2004 03:20 AM |
| Regulated or no regulated PSU? | Higo | Chip Amps | 2 | 16th July 2003 04:38 PM |
| Page generated in 0.09617 seconds (84.47% PHP - 15.53% MySQL) with 11 queries |
