DIY Turntable
DIY Turntable
Old 12th June 2002, 01:19 PM   #21
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Tonite I had a look at the no-name cartridge in my $10 Technics turntable and held a small drill bit near it and couldn't feel a thing. A 1.5 thou feeler gauge only barely responded so there was a very weak external field with this cartridge. So it must vary from one type to the next. Or perhaps the magnets in mine have simply fizzed out.
GP.
Old 12th June 2002, 01:29 PM   #22
hifidaddy is offline hifidaddy  Germany
then you probably have a moving magnet cartridge, and not a moving coil cartridge. Moving coils have lot of magnetic energy outside.
regards,
Hartmut
Old 12th June 2002, 01:40 PM   #23
dice45 is offline dice45  Germany
Hartmut and all,
a drill bit put in the proximity of a Scheu-Benz or a Hul Grasshopper, a nightmare !! "click !!" ... "%#+*%#$%$% !!!! ....
see above, me was lucky once, but twice !? ... luck is if you spoil the cheap MC by such a stunt and let the expensive one survive ...
Bernhard
Old 6th July 2002, 08:33 PM   #24
AuroraB and all,
concerning belt stickyness, well, i modified my point of view. My old trusty TT undergoes a modification, it gets a new plinth able to carry two linear tonearms or 12"ers if desired. And on this occasion i moved the motor (which is a maxon DC motor from now) from platter edge proximitiy to the utmost outer corner of the plinth. The old motor, a Pabst GS3809, consumed too much space for such.
So the motor changes from AC synchonous to DC ascynchronous with practically zero torque ripple and i do not need the pulley's speed variations to drown in belt slip anymore. The belt will be a magnetic tape (and slippery as such) but the angle of the belt wrapping around the pulley is much bigger. Belt slip will be history, i presume.
Bernhard
Old 7th September 2002, 12:57 AM   #25
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Dice,
Any news on this tape-belt ?
If you had slip for a while (metal-polyester) wouldn't it burn?
Have you tried non-waxed dental floss yet? No kidding,all the Japanese audiophiles have a healthy set of biters,you know.
I guess you also require a decent tape-splicing device to work with?
Greetz,
Frank
DIY TurntableHide this!Advertise here!
Looking for a turntable bgatlin Swap Meet 1 15th December 2005 08:52 PM
New turntable rocknroll Analogue Source 5 9th January 2004 05:52 PM
