Pearl Phono stage output matching? - diyAudio
Old 29th June 2004, 04:59 PM   #1
Default Pearl Phono stage output matching?
I'm getting ready to build a Pass Pearl phono stage. The cartridge that I'm using is a Ortofon Kantrapunkt A which has 450uV ouput voltage and a recommended load impeadance of 50-500 Ohm. I will run the phono stage into an active preamp. Will this phono stage work with this set up or will it have to be modified some how?
GE
Gregorio
Old 30th June 2004, 02:06 PM   #2
diyAudio Member RIP
Just to be a bit clearer than my answer in the other post.
The Ortofons output is bang in the middle of the range the
Pearl was tested, (400uV to 500uV), so it should be fine
when used with an active preamp.
You just need to set input impedance to 100R.
sreten.
MC Stage for Pearl Phono Panelhead Pass Labs 7 6th November 2005 12:30 AM
Pearl Phono stage Gregorio Pass Labs 4 2nd June 2005 06:03 PM
Pearl Phono stage dhole Pass Labs 4 29th July 2004 04:15 PM
Pearl Phono stage cartridge matching Gregorio Pass Labs 3 30th June 2004 10:10 AM
MC Stage for Pearl phono Panelhead Pass Labs 7 31st October 2003 09:16 AM
Copyright 1999-2017 diyAudio
