| Analogue Source Turntables, Tonearms, Cartridges, Phono Stages, Tuners, Tape Recorders, etc. |
I am enrolling in "kindergarten" as far as analog turntables are concerned. I have received a Kenwood KD-500 TT with an Infinity Black Widow tone arm. It is mounted but has no chord with it. The connection is a 5 pin socket type plug under the tone arm mounting. I will be running the signal to a Pioneer Spec-1 preamp with a Nakamichi 430 power amp. Can anyone recommend what I need for the phono chord? Is there a complete chord made to fit the Black Widow that can be ordered?
Really, I have learned most of the terms I have used in my post during the last week. Thanks to all in advance |
#2 |
If you are lucky you will find a old replacement part, they are
certainly no longer made, and there isn't such a thing as a "standard tonearm" lead a manafacturer could make, though some arm leads are interchangeable. Hopefully someone has the correct lead lying around, or I'm afraid it will be rewiring job and making the lead. Try here also : http://www.nakedresource.com/phpBB2/...1092c227062851 sreten.
#3 |
I have an Audio-Technika tone arm which uses a 5 pin DIN connector at the base of the arm.
Perhaps their connector will fit your tone arm. You might need to purchase an assembly from them and re-wire the connector to fit your arm. I wish you luck.
Frank |
#4 | |
Male/female is usually reversed, a plug resembles a socket and vice versa. (That is for tonearms the socket has the pins, quite unlike DIN) sreten.
#5 |
"No tonearm I've ever seen has a 5 pin connector according to DIN standards."
Who said anything about DIN standards? It's a 5 pin DIN connector. I'm looking at it as I type.
Frank |
#6 | |
in this case DIN is a useless qualification, its simply a 5 pin inline tone-arm connector. It would be quite significant to someone ordering a 5 pin DIN plug to 2 phono plugs lead / adaptor. sreten.
#7 |
That's why I said:
"You might need to purchase an assembly from them and re-wire the connector to fit your arm."
Frank |
#8 | |
generally it is not possible to rewire the arm connector. sreten.
#9 |
You might be able to rewire the connector the plugs into the arm.
This is the connector the plugs into my A-T tonearm.
Frank |
#10 |
Well IMO if the connector fits into the arm its unlikely
to need rewiring, and if it does rewiring the connector in the arm is probably going to be easier. There a couple of very murky shots of the connector in the manual from Vinyl Engine, doesn't help much. Except you could probably rewire using a S-VHS plug and socket if a lead doesn't turn up, or if it comes to it hardwire to the socket pins. sreten.
| Black Widow info here... | Russellc | Analogue Source | 5 | 5th November 2008 08:29 PM |
| NEED HELP on my Kenwood KD-500 and the Infinity Black Widow Tone Arm | EJCUSA1 | Analogue Source | 3 | 22nd May 2004 06:21 PM |
| Kenwood KD-500 and the Black Widow NEED HELP | EJCUSA1 | Analogue Source | 4 | 21st May 2004 05:09 PM |
| Infinity Black Widow | mavz | Analogue Source | 7 | 13th February 2004 01:31 AM |
| Black Widow tonearm setup | FrankW | Analogue Source | 3 | 13th January 2004 10:33 PM |
